Sandisk 4GB Extreme III Compact Flash
Old 24-02-2007, 11:53 AM   #1
7,346, Level: 20
Points: 7,346, Level: 20 Points: 7,346, Level: 20 Points: 7,346, Level: 20
Thanks: Gave 6, Got 5
hi guys
does anyone know of a cheeper one
http://www.emartbuy.co.uk/products.p...ryType=Compact Flash (CF)&megcap=
santana007
Old 24-02-2007, 1:07 PM   #2
3,023, Level: 12
Points: 3,023, Level: 12 Points: 3,023, Level: 12 Points: 3,023, Level: 12
Thanks: Gave 0, Got 15
Re: Sandisk 4GB Extreme III Compact Flash
£39.99 delivered from www.play.com
santana007 (24-02-2007)
Old 24-02-2007, 6:36 PM   #3
M-C-P-M's Avatar
4,277, Level: 15
Points: 4,277, Level: 15 Points: 4,277, Level: 15 Points: 4,277, Level: 15
Thanks: Gave 74, Got 118
Thanks for that little link, i've recently bought one off of Ebay and it was a fake so this is a chance to get a descent one for a really good price
Old 24-02-2007, 6:48 PM   #4
garysherpa's Avatar
3,805, Level: 14
Points: 3,805, Level: 14 Points: 3,805, Level: 14 Points: 3,805, Level: 14
Thanks: Gave 0, Got 17
have a look on 7dayshop
Old 24-02-2007, 8:48 PM   #5
M-C-P-M's Avatar
4,277, Level: 15
£79.99
Old 24-02-2007, 8:51 PM   #6
wobblebottom's Avatar
7,314, Level: 20
Points: 7,314, Level: 20 Points: 7,314, Level: 20 Points: 7,314, Level: 20
Thanks: Gave 389, Got 153
http://www.memorycardzoo.co.uk/Produ...brand/2/size/6
Memory card zoo
Old 25-02-2007, 8:13 AM   #7
8,837, Level: 22
Points: 8,837, Level: 22 Points: 8,837, Level: 22 Points: 8,837, Level: 22
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 251, Got 370
www.mymemory.co.uk
Old 25-02-2007, 1:13 PM   #8
16,515, Level: 31
Points: 16,515, Level: 31 Points: 16,515, Level: 31 Points: 16,515, Level: 31
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 89, Got 183
the 39.99 ones from play -are they Extreme IIIs or Extreme IVs ?
Mark.
Old 25-02-2007, 2:30 PM   #9
3,977, Level: 14
Points: 3,977, Level: 14 Points: 3,977, Level: 14 Points: 3,977, Level: 14
Thanks: Gave 4, Got 14
Extreme IIIs
Old 25-02-2007, 2:46 PM   #10
Radiohead's Avatar
15,086, Level: 29
Points: 15,086, Level: 29 Points: 15,086, Level: 29 Points: 15,086, Level: 29
Thanks: Gave 327, Got 450
Damn that's a very good price from Play.
Old 26-02-2007, 8:46 AM   #11
h4rri's Avatar
7,667, Level: 20
Points: 7,667, Level: 20 Points: 7,667, Level: 20 Points: 7,667, Level: 20
Thanks: Gave 37, Got 173
Thought that too so ordered
Old 26-02-2007, 11:31 AM   #12
toadoftoadhall's Avatar
4,554, Level: 16
Points: 4,554, Level: 16 Points: 4,554, Level: 16 Points: 4,554, Level: 16
Thanks: Gave 2, Got 26
anyone know if the Phase One LE free registration is still on with the Extreme cards?
Its a RAW converter, usually $100 but used to have a free registration late last year on the back of the product, or inside.
thanks
toad
Old 26-02-2007, 11:38 AM   #13
allymac123's Avatar
9,729, Level: 23
Points: 9,729, Level: 23 Points: 9,729, Level: 23 Points: 9,729, Level: 23
Thanks: Gave 489, Got 451
Didn't notice it on my card i bought a month ago.
Old 26-02-2007, 5:14 PM   #14
16,515, Level: 31
Activity: 2.7%
well on the ones from picstop for 4.99 more it still quotes them having PhaseOne with them
Old 01-03-2007, 11:10 AM   #15
M-C-P-M's Avatar
4,277, Level: 15
Well i guess i just be the unluckiest bloke in the world i bought one of the play.com Sandisk extremeIII 4gb and it turned up this morning and it was bloody faulty
Oh well i'll try again
Old 01-03-2007, 12:29 PM   #16
h4rri's Avatar
7,667, Level: 20
Mine just arrived, will have to check for faults
Old 01-03-2007, 2:39 PM   #17
5,097, Level: 16
Points: 5,097, Level: 16 Points: 5,097, Level: 16 Points: 5,097, Level: 16
Thanks: Gave 21, Got 14
thanks
toad
Well, I bought a CF card latter part of last year, with the Phase One deal, and I took it up. All I can remember was that the closing date wasn't far off, I'll try and find it and see. You never know, though, they may update the deal with each new batch?
Old 01-03-2007, 2:40 PM   #18
5,097, Level: 16
thanks
toad
Well, I bought an Extreme III 4Gb CF card latter part of last year, with the Phase One deal, and I took it up. All I can remember was that the closing date wasn't far off, I'll try and find it and see. You never know, though, they may update the deal with each new batch?
Old 01-03-2007, 2:49 PM   #19
h4rri's Avatar
7,667, Level: 20
You get a copy of Capture One RAW free with a reduced price upgrade to Capture One Pro with the new batch of cards.
Old 01-03-2007, 2:52 PM   #20
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Not Sandisk - Maybe the cheapest though
Ahoy!
Try this link. OK, it may not be the fastest, but for the price . . .
Specs here.
Read the small print as the actual card supplied may not actually be the make shown.
Old 01-03-2007, 3:14 PM   #21
Conspicuous Member
stevegreen's Avatar
30,635, Level: 42
Points: 30,635, Level: 42 Points: 30,635, Level: 42 Points: 30,635, Level: 42
Thanks: Gave 1,182, Got 1,020
Re: Not Sandisk - Maybe the cheapest though
Play are out of stock now, but I've ordered one anyway.........along with Borat!
Jagshemash!
Old 01-03-2007, 4:53 PM   #22
h4rri's Avatar
7,667, Level: 20
Jagshemash!
They were out of stock when I ordered mine but it still arrived today
Old 01-03-2007, 6:17 PM   #23
16,515, Level: 31
Activity: 2.7%
before you send it back - can you check its not a fake- not that I'm suggested play.com deliberately sell them - but there are so many fakes around it wouldn't be impossible:
see here
http://reviews.ebay.com.au/FAKE-SanD...00000001449653
