vanity question regarding photoshop
Old 15-01-2007, 4:01 PM   #1
5,854, Level: 18
Points: 5,854, Level: 18 Points: 5,854, Level: 18 Points: 5,854, Level: 18
Thanks: Gave 71, Got 60
Talking vanity question regarding photoshop
a few months ago i took some photos at a 21st birthday party, anyway one of the girls who was at the party was a bit on the chubby side,having seen i had done some post processing work on some of the photos like eye colouring etc, she asked me if you can make people appear a bit thinner in photos, particularly with removing double chins, i said i thought it may be possible but was'ent sure how to do it myself, so basically thats the question to you guys, can it be done and if so how ? i guess i should have told her to go on a diet but really did'ent have the heart, plus i did'ent really fancy a crack around the head
Old 15-01-2007, 4:18 PM   #2
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: vanity question regarding photoshop
Ask Wabbit
Hes the Man
wabbitt (15-01-2007)
Old 15-01-2007, 4:26 PM   #3
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Try this link
Ahoy!
I was going to post this link in a separate thread, but it may have the answers you seek (I don't know).
In any case, anyone using CS2 ought to find it useful.
Old 15-01-2007, 4:56 PM   #4
4,862, Level: 16
Points: 4,862, Level: 16 Points: 4,862, Level: 16 Points: 4,862, Level: 16
Thanks: Gave 14, Got 18
I asked my friend, who also photographed my wedding, if he could do something about a couple of chins and other lumps and bumps that were present in some of the photo's. His response was that he was 'a photographer not a plastic surgeon!'
Old 15-01-2007, 5:07 PM   #5
Liquid101's Avatar
15,145, Level: 29
Points: 15,145, Level: 29 Points: 15,145, Level: 29 Points: 15,145, Level: 29
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 599, Got 1,489
Liquify is the tool you're looking for.
It's hidden under filters in Photoshop 7 onwards I believe.
Anyway, rather than try and explain how to use it here, you're better off opening it up and having a play on your own, it's all pretty basic stuff.
Good luck
Edit: Just to remind myself, I had a quick play with it. One thing that I remember that is quite important: Use a larger brush size than you think, it's easier to get a smoother finish, especially if you're 'moving' legs, tummys etc.
Old 15-01-2007, 5:52 PM   #6
wabbitt's Avatar
7,459, Level: 20
Points: 7,459, Level: 20 Points: 7,459, Level: 20 Points: 7,459, Level: 20
Thanks: Gave 160, Got 116
Liquid is spot on. Liquify tool all the way, and mentioned a larger brush will be better than a smaller one to give a better effect. Reduce the size only when you get into tight spots, for example between an arm and the side of the body when you don't want to affect the arm.
Using marquee selections before you start the liquify tool will also help a lot.
Always make a copy of your original layer as it's very easy to go too far with this tool.
Here's some examples. Roll mouse over each image to see before shots.
Mild change
Slightly more change
Fairly major change
Old 15-01-2007, 8:47 PM   #7
wabbitt's Avatar
7,459, Level: 20
Just for fun I thought I'd take well known celebrity, Kelly Osbourne, and 'downsize' her.
This was all the liquify tool as Liquid101 mentions.
Old 15-01-2007, 9:31 PM   #8
electrolyte's Avatar
15,316, Level: 29
Points: 15,316, Level: 29 Points: 15,316, Level: 29 Points: 15,316, Level: 29
Thanks: Gave 1,458, Got 1,030
Wow, they are amazing Wabbitt, especially the transformation in Kelly Osbourne! She looks quite fit in your version.
I had no idea that was what the liquefy tool could be used for. I have given it a go and it is really easy to use. So thanks for the top tip.
Old 15-01-2007, 9:40 PM   #9
12,098, Level: 26
Points: 12,098, Level: 26 Points: 12,098, Level: 26 Points: 12,098, Level: 26
Thanks: Gave 1,568, Got 761
Unbelieveable wabbit.I have to learn how to do that!.Any time ive tried using the liquify tool ,they end up looking like Klingons
Remarkable
Old 15-01-2007, 9:50 PM   #10
wabbitt's Avatar
7,459, Level: 20
Thanks guys. It is pretty easy to use once you get the hang of it.
Remarkable
Another tip I just remembered. The liquify tool is quite strong when you first use it as default. Reduce the Brush Density to around 40 or 50 and the effect you apply is much more manageable.
Hope that helps everyone a bit.
electrolyte (16-01-2007), tontoshorse (15-01-2007), vulkan75 (15-01-2007)
Old 15-01-2007, 11:07 PM   #11
Liquid101's Avatar
15,145, Level: 29
Activity: 9.1%
Nice work wabbit - makes the real Kelly look like David Coulthard!
Old 16-01-2007, 4:30 AM   #12
3,608, Level: 14
Points: 3,608, Level: 14 Points: 3,608, Level: 14 Points: 3,608, Level: 14
Thanks: Gave 12, Got 76
Wow, how did u add those tatoos? They look amazing!
Old 16-01-2007, 9:28 AM   #13
wabbitt's Avatar
7,459, Level: 20
Thanks.
I just did a web search for tattoos and when I found a pattern that I liked (the dragon in this case) I made sure it was a black pattern on a transparent background.
Then I placed the tattoo roughly where I wanted it and scaled it correctly. Using the liquify tool (again) I made sure it followed the contours of the back. The blend mode was then changed to Linear Burn which makes it look more like it's etched into the skin.
I reduced the opacity slightly and then added a slight blur to make it look realistic as possible.
It's a good thing to try and can look quite realistic most of the time.
If you have a colour tattoo then you might want to try some other blend modes (soft light and hard light seem to work well).
Old 16-01-2007, 9:38 AM   #14
6,416, Level: 19
Points: 6,416, Level: 19 Points: 6,416, Level: 19 Points: 6,416, Level: 19
Thanks: Gave 33, Got 148
the liquify tool has always been a way to beat bordom for me! just open up a photo of someone and mess them up, like its been said, use a bigger brush than you think you need. This might be the reason people look like klingons after being processed! dont make the changes to drastic. The kelly osbourne pic is a good example, the tool has worked well but nobody would know thats kelly!
Dont make your friend unrecognisable!
Old 16-01-2007, 11:08 AM   #15
5,854, Level: 18
thanks for that wabbit, that is the type of effect i was after, i will have a play with that liquify tool, thats a major difference in kelly osbourne, she actually looks quite nice now.
Old 16-01-2007, 5:18 PM   #16
12,098, Level: 26
Will Give it another go when I get the chance.Thanks mate
Old 17-01-2007, 8:20 AM   #17
Mark Ward's Avatar
12,381, Level: 26
Points: 12,381, Level: 26 Points: 12,381, Level: 26 Points: 12,381, Level: 26
Thanks: Gave 98, Got 17
Do you need the full Photoshop to get this liquify feature?
I'm a dedicated Paint Shop Pro user (Version 9 at the Moment, but been using since version 4). I'm only a domestic consumer user but have been considering trying Elements.
Mark.
