The Carnal Sin!
Old 20-12-2006, 1:20 PM   #1
geofftelforduk's Avatar
11,339, Level: 25
Points: 11,339, Level: 25 Points: 11,339, Level: 25 Points: 11,339, Level: 25
Thanks: Gave 63, Got 155
The Carnal Sin!
Guys,
I have heard that I have just committed the carnal sin!!! I have sold my iMac to buy a PC!!
I bought the iMac about a year ago, and I have to say it was a really good machine, but I just found it difficult to get used to when I am so used to a PC (i.e. Windows PC).
There were a couple of things that I didnt like about it. I hated the mouse movement on it. Believe me, I tried every mouse known to man to try and rectify it. There were a couple of other things that I didnt like, but i wont bore ya.
Basically, in the New Year I intend to build a new PC. From experience is there anything in particulat that I should look out for (I have experience in PC building) being out of the PC arena for about a year or so. For example, AMD or Intel!!??
Any tips and good online retailer references would be appreciated!
Geoff
Old 20-12-2006, 1:38 PM   #2
WSB WSB is offline
6,449, Level: 19
Points: 6,449, Level: 19 Points: 6,449, Level: 19 Points: 6,449, Level: 19
Thanks: Gave 10, Got 6
Re: The Carnal Sin!
I built a box about a year or so ago but it was more of a budget thing. (Happily bagged myself a macbook a few weeks ago with the newer core 2 duo processors with 2 gig of mem and trying to learn to use Aperture now!)
You can get a good barebones unit from ebay and build it up or make your own....ebuyer always seem to offer everything you need at a decent price.
On another project I turned a dell into a very very decent media center so perhaps you could see what Dell offer in the new year and buy the bits to upgrade it yourself. To be honest- building your own PC from sratch will prob be more expensive.
Look at the 'entertainment computers' section on the forum for advice but if I was going for a new machine I'd go for Intel Core 2 Duo, min 2 gig of mem (should be enough for photo editing but if you do camcorder stuff you may want more) and a decent graphics card.
Old 20-12-2006, 1:54 PM   #3
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
Re: The Carnal Sin!
I'd also go the Intel dual core route.
Also look for DDR2 memory and PCIe graphics.
Get a motherboard with as many slots as you can find because it's a pain to have to remove cards when you want to fit extras!
Personally I'd get a sound card as well as I hate having on board sound.
BTW www.novatech.co.uk do some good motherboard bundles, but ebuyer can be cheaper for drives etc.
HTH.
Old 20-12-2006, 2:14 PM   #4
Conspicuous Member
pixelpixel's Avatar
24,051, Level: 37
Points: 24,051, Level: 37 Points: 24,051, Level: 37 Points: 24,051, Level: 37
Activity: 32.8%
Activity: 32.8% Activity: 32.8% Activity: 32.8%
Thanks: Gave 1,619, Got 1,182
Re: The Carnal Sin!
Originally Posted by geofftelforduk View Post
Guys,
I did something like that when I moved across the water, sold my G4 PowerMac and ibook. I now have a old 3 year old pc that is about to have linux installed shortly.
Do miss my G4...
Old 20-12-2006, 2:23 PM   #5
11,339, Level: 25
Re: The Carnal Sin!
Have you any specific reason why you would go for Intel!!! There is a significant price difference!!
Old 20-12-2006, 3:10 PM   #6
onefivenine's Avatar
17,895, Level: 32
Points: 17,895, Level: 32 Points: 17,895, Level: 32 Points: 17,895, Level: 32
Thanks: Gave 687, Got 665
Re: The Carnal Sin!
If you're interested in HDTV make sure you get a graphics card which supports HDCP. They've only recently come on the market.
Old 20-12-2006, 3:53 PM   #7
Radiohead's Avatar
15,086, Level: 29
Points: 15,086, Level: 29 Points: 15,086, Level: 29 Points: 15,086, Level: 29
Thanks: Gave 327, Got 450
Re: The Carnal Sin!
I just went the other way, from a PC to a C2D iMac. I'd never go back now.
Old 20-12-2006, 4:05 PM   #8
Conspicuous Member
pixelpixel's Avatar
24,051, Level: 37
Activity: 32.8%
Re: The Carnal Sin!
I dont have a hdcp card but have enjoyed HD material for over a year now.
Old 20-12-2006, 4:36 PM   #9
17,895, Level: 32
Re: The Carnal Sin!
Same here mate. Not everyone has a wooden leg and an eye patch though
Anyone that goes down the HD-DVD drive route will probably benefit from a card with HDCP just in case they have some legitimate material!
I just mentioned it for the OP as it's the only thing I could think of that's changed significantly in the last year which I would watch out for now if I was upgrading or building.
The gfx card can be a relatively big outlay in a PC's cost.
Old 20-12-2006, 4:46 PM   #10
6,996, Level: 19
Points: 6,996, Level: 19 Points: 6,996, Level: 19 Points: 6,996, Level: 19
Thanks: Gave 23, Got 40
Re: The Carnal Sin!
Carnal sin or cardinal sin?
Old 20-12-2006, 4:53 PM   #11
7,818, Level: 21
Activity: 4.8%
Re: The Carnal Sin!
I just find Intel more reliable, simple as that really.
...can open, worms everywhere...
Old 20-12-2006, 5:35 PM   #12
Conspicuous Member
20,522, Level: 34
Points: 20,522, Level: 34 Points: 20,522, Level: 34 Points: 20,522, Level: 34
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
Thanks: Gave 86, Got 384
Re: The Carnal Sin!
Yes I was wondering if he was commiting forbidden acts with his iMac.
Old 20-12-2006, 6:00 PM   #13
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: The Carnal Sin!
Hmm...
Some will consider selling off a Mac to get a PC committing a forbidden act!!
Old 20-12-2006, 7:29 PM   #14
toadoftoadhall's Avatar
4,554, Level: 16
Points: 4,554, Level: 16 Points: 4,554, Level: 16 Points: 4,554, Level: 16
Thanks: Gave 2, Got 26
Re: The Carnal Sin!
one thing to watch out for is noise.
Get some decent fans, not cheap and noisy, and some sort of fan speed controller.
toad
Old 20-12-2006, 7:37 PM   #15
3,608, Level: 14
Points: 3,608, Level: 14 Points: 3,608, Level: 14 Points: 3,608, Level: 14
Thanks: Gave 12, Got 76
Re: The Carnal Sin!
It's not a can of worms anymore (Though i do believe AMD are just as stable as Intel, and with the old P4s AMDs were MUCH more stable due to the temps on P4 chips). However, AMD are the fallen kings. All hail Intel!
Intel are faster and cheaper than AMD since the core2duo hit the shelves. Don't look at clock speeds whatever you do. At EVERY single level from budget to top end, Intel kicks AMDs ass in priceerformance. Not only that they have the fastest chips available aswell (also cheaper than AMDs top end)
<---- Using a AMD x2 4800+ currently. Will be going the Intel route next, unless AMD pull somethign special out of the bag. Story on the grape vine however is that it will be a couple of years until they can "pull a conroe" on Intel.
Old 21-12-2006, 1:00 PM   #16
47,154, Level: 53
Activity: 2.7%
Re: The Carnal Sin!
Originally Posted by Valleyman View Post
.......... However, AMD are the fallen kings. All hail Intel!
Intel are faster and cheaper than AMD since the core2duo hit the shelves...
For now
I hope not. Intel has not become a monopoly because of healthy competition from AMD. The thought of them having no competition brings back nightmares of "Wintel" and all its negatives
Old 21-12-2006, 1:04 PM   #17
11,339, Level: 25
Re: The Carnal Sin!
Guys! Please accept my humblest apology for the typo!!!! I am no PCophile!
Keep the advice coming cos I am not intending to do anything till the New Year!!
