Originally Posted by bowenjones Hi Pirate.
Although you already have the tools for editing RAW files, i'd recommend downloading Rawshooter Essentials. Really easy to use and it's free. I find that although I have CS2, most of my Raw processing is done using Rawshooter as it's so good. Give it a try  |
This is what I use, it is simple yet powerful. The best bit, now I am used to it, is that if I have taken 20-30 simillar photos in a shoot, I can copy and paste all the related changes to all the selected shots Then check them, and if all is ok, batch process them without having to 'develope' evey picture individually. You can normally tell in the preview which ones will need the same processing.
Once you have set this baseline, it is easy to individually tweak each shot if required before the background processing. It also avoids wild changes in White balance and exposure between the shots, which it is wasy to do when processing individually.
It gives you great flexibility and means that under exposed shots can be 'rescued' a lot easier than trying to fix an out of camera Jpeg. It's been a god-send a number of times since I started using it, esecially for indoor shoots when it is easy to get exposure and colour temp wrong.
The downside is the extra step you have to take to develope the shots, but I reckon it is worth it.
