Originally Posted by monkeyleader
So my question - is there a perfect histogram we should be looking to achieve or does it really depend on the situation? |
The perfect histogram is one which shows that you are losing no detail in either shadow or highlight. In simple terms, It should be perfectly flat just before 0 and perfectly flat just before 255.. with all of your pixels lying between the two. If you have pixels right on the edge then the likelyhood is you're losing detail which can not be retrieved.
Obviously if you have a very high key shot with lots of highlight detail, like a snowscape, most of your pixels are going to be positioned to the right of centre on the histogram. If you have a spike on the edge, then adjust exposure to bring the detail back onto the histogram. The same applys to shadows. In an ideal digital photograph you will have no black or white pixels at all, this will give you plenty to work with afterwards - In reality, this is quite hard to achieve on a perfect sunny day!
I can understand why some people might suggest having a lightly overexposed image, as digital camera sensors are much better at recording mid tones than shadows, but beware of losing highlight detail.
HTH
