Recommendation for spare battery for Canon EOS 400D
Old 07-11-2006, 3:54 PM   #1
3,281, Level: 13
Points: 3,281, Level: 13 Points: 3,281, Level: 13 Points: 3,281, Level: 13
Activity: 3.6%
Activity: 3.6% Activity: 3.6% Activity: 3.6%
Thanks: Gave 47, Got 3
As with most of my stuff, to avoid charge going at the wrong time, I'm looking to buy a second battery for my camera. The battery I need is a Canon NB-2LH.
I;m after two recommendations:
1. A reasonable (cheap !!) genuine Canon batter; or
2. A generic make which is reliable (i.e. won't leak/explode)
Cheers.
Old 07-11-2006, 4:54 PM   #2
Nick Cartwright
Posts: n/a
Re: Recommendation for spare battery for Canon EOS 400D
I don't have a Canon, but I got a Uniross, Olympus equivelent for my E500 and it is exceptionally reliable and lasts for ages on a charge. It was £12.99 but I can't remember where I got it from as the receipt email is on my home PC.
EDIT :
Found the place, had a quick search for product code on www.uniross.com and then a quick google threw up a name I recognised.
http://www.gmkbatteries.co.uk/uniros...ry-p-1024.html
Just over £12, can't go wrong. Think they are guaranteed for quite a while too.
taposh (08-11-2006)
Old 07-11-2006, 9:15 PM   #3
Conspicuous Member
51,248, Level: 55
Points: 51,248, Level: 55 Points: 51,248, Level: 55 Points: 51,248, Level: 55
Thanks: Gave 382, Got 418
I got two from ebay for the battery grip. They are higher capacity and I never use my canon one now unless I run out of juice on them. I think I paid £9.99 each, I will have a look at the name and let you know (at work).
taposh (08-11-2006)
Old 08-11-2006, 12:32 PM   #4
WSB WSB is offline
6,449, Level: 19
Points: 6,449, Level: 19 Points: 6,449, Level: 19 Points: 6,449, Level: 19
Thanks: Gave 10, Got 6
I got my 350D spare battery from 7dayshop
http://www.7dayshop.com/catalog/prod...oducts_id=8346
it was 6.50 so bargain price. I think shipping is around 5 pounds so make sure you buy a few other bits and bobs...50p for microfibre cloths which is a bargain (waiting for one of the avforums bargain oracles to correct me and say youi can get them for free now!)
Anyway- hope that helps.
sr1312 (16-11-2006), taposh (08-11-2006)
Old 16-11-2006, 8:03 PM   #5
4,296, Level: 15
Points: 4,296, Level: 15 Points: 4,296, Level: 15 Points: 4,296, Level: 15
Thanks: Gave 5, Got 4
WSB,
Does that battery fit in the canon charger or do you need to buy the charger to go with it ?
Old 16-11-2006, 10:39 PM   #6
nokiauk's Avatar
5,613, Level: 17
Points: 5,613, Level: 17 Points: 5,613, Level: 17 Points: 5,613, Level: 17
Thanks: Gave 56, Got 51
they are NB-2LH replacement so same charger will work fine
i recommendthe twin pack - 2 for £10.99 & 3.95 delivery
Twin Pack
sr1312 (16-11-2006)
