Fuji S7000 - Flash Memory query?
Old 25-10-2006, 11:09 AM   #1
PaulBoy's Avatar
9,371, Level: 23
Points: 9,371, Level: 23 Points: 9,371, Level: 23 Points: 9,371, Level: 23
Thanks: Gave 58, Got 90
Not sure if anyone here has/had one of these (?) A colleague at work wants to buy some memory & currently uses a 512mb CF card (you can also use xD cards but they're sh!te he tells me) - I found a few reviews which stated some 1gb CF cards were OK but don't know if you can use 2gb CF cards (which is the best "bang for buck" option) - any help greatly appreciated ...
Paul
Old 25-10-2006, 7:22 PM   #2
Conspicuous Member
Crocodile's Avatar
15,118, Level: 29
Points: 15,118, Level: 29 Points: 15,118, Level: 29 Points: 15,118, Level: 29
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 408, Got 1,147
Re: Fuji S7000 - Flash Memory query?
My missus has an S7000 & it's unfussy with 1Gb cards - I don't own anything larger. Fuji use a fairly aggresive compression so I wouldn't bother with 2Gb.
The camera can't make use of high speed media so unless read time is important, just go for whatever's cheap & cheerfull at Mymemory or Picstop this week.
PaulBoy (26-10-2006)
Old 26-10-2006, 6:01 AM   #3
PaulBoy's Avatar
9,371, Level: 23
Thanks Croc - I'll get him to buy a cheapo 2gb one from 7dayshop & if the Fuji doesn't like it I'll swop it for my Sandisk 1gb one
Paul
