polariser??
Old 27-09-2006, 4:46 PM   #1
petrolhead's Avatar
16,379, Level: 30
Points: 16,379, Level: 30 Points: 16,379, Level: 30 Points: 16,379, Level: 30
Thanks: Gave 97, Got 54
polariser??
Have a 10-22 Canon and been thinking about a polariser.
Does anyone have shots with and without so I can what the benefit is
Old 27-09-2006, 5:17 PM   #2
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Re: polariser??
A poliarizing filter will reduce/remove glare from surfaces (window reflections/paintwork) etc and water. Normally, these have a rotating ring so you can all but eliminate glare.
I have one for each of my cameras and they are worth the investment. Go get one.
Old 27-09-2006, 5:47 PM   #3
wabbitt's Avatar
7,459, Level: 20
Points: 7,459, Level: 20 Points: 7,459, Level: 20 Points: 7,459, Level: 20
Thanks: Gave 160, Got 116
Re: polariser??
Be careful to get a circular polariser and not the cheaper linear ones too.
Linear ones don't work too well with digital.
Also if the front of your lens rotates when you zoom.... well, be careful of that too because it will affect the polarising once you've set it.
Old 27-09-2006, 6:24 PM   #4
6,617, Level: 19
Points: 6,617, Level: 19 Points: 6,617, Level: 19 Points: 6,617, Level: 19
Re: polariser??
Polarisers can be quite thick too and on a 10-22 lens you will need to make sure you get a very thin one to avoid vignetting.
Old 28-09-2006, 7:25 AM   #5
h4rri's Avatar
7,667, Level: 20
Points: 7,667, Level: 20 Points: 7,667, Level: 20 Points: 7,667, Level: 20
Thanks: Gave 37, Got 173
Re: polariser??
It would have to be a wide angle version
Old 28-09-2006, 9:04 AM   #6
6,996, Level: 19
Points: 6,996, Level: 19 Points: 6,996, Level: 19 Points: 6,996, Level: 19
Thanks: Gave 23, Got 40
Re: polariser??
Wide angle polarisers are expensive unfortunately, but they really add a dramatic element to pictures.
The detail in clouds jumps out, glare across water or metal disappears (it's still bright, but you can see details), etc.
The filter will reduce the light entering your lens, so you'll need a wider aperture and/or faster shutter.
It's also worth pointing out that any glass or plastic that's you photograph (and wet rocks sometimes) will exhibit a rainbow effect - perhaps not quite true to what the eye can see, but it can look pretty groovy
Here's a couple of "good" examples:
Here's some more of mine, and here are a whole bunch of other Flickrites ones...
Old 28-09-2006, 4:36 PM   #7
45,504, Level: 52
Points: 45,504, Level: 52 Points: 45,504, Level: 52 Points: 45,504, Level: 52
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 378, Got 854
Re: polariser??
can the wide angle ones prevent the effect you get with uneven polarisation, or are they just thinner to prevent vignetting?
I found with the Sigma 10-20 that at the wider ends you'd get uneven polarisation, so that parts of the sky would be darker blue, and others lighter blue.
Old 28-09-2006, 6:08 PM   #8
petrolhead's Avatar
16,379, Level: 30
Re: polariser??
Cheers for the feedback so far
Old 29-09-2006, 9:16 AM   #9
Alan_W's Avatar
5,505, Level: 17
Points: 5,505, Level: 17 Points: 5,505, Level: 17 Points: 5,505, Level: 17
Thanks: Gave 109, Got 179
Re: polariser??
But have you seen the price of a 77mm polariser
Old 29-09-2006, 9:57 AM   #10
h4rri's Avatar
7,667, Level: 20
Re: polariser??
£57 for a Kenko one was the cheapest I have seen. TBH I never managed to get to grips with the ones I have so haven't bought one for the 10mm yet. Might do in time but before I sink £100 into a filter I want to know I can get the best from it
Old 29-09-2006, 5:45 PM   #11
7,883, Level: 21
Points: 7,883, Level: 21 Points: 7,883, Level: 21 Points: 7,883, Level: 21
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 127, Got 129
Re: polariser??
This shot here was taken with a Circular Polariser on my Canon 350D and you can certainly see the benefit with the bright colours and the deep blue sky.
I would definitely get one as they can really bring out clouds and help saturate colours.
See ya,
Mike.
Old 29-09-2006, 5:51 PM   #12
QuietRiot1983's Avatar
5,567, Level: 17
Points: 5,567, Level: 17 Points: 5,567, Level: 17 Points: 5,567, Level: 17
Thanks: Gave 52, Got 53
Re: polariser??
See ya,
Mike.
That looks awesome!
