remote control
Old 27-09-2006, 2:11 PM   #1
tony79's Avatar
4,934, Level: 16
Points: 4,934, Level: 16 Points: 4,934, Level: 16 Points: 4,934, Level: 16
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 72, Got 90
remote control
has anyone got any suggestions for a remote control for the 350d. was interested in the TC-80N3 but dont know if its compatible or not. any other suggestions would be great. would be used mainly in studio behind the camera and also for long exposure landscape photography. thanks
Old 27-09-2006, 3:21 PM   #2
Kaoshan's Avatar
2,617, Level: 11
Points: 2,617, Level: 11 Points: 2,617, Level: 11 Points: 2,617, Level: 11
Thanks: Gave 8, Got 21
Re: remote control
The plug on the TC-80N3 is not compatible with the 350D which requires a mini jack plug to connect. You need one of these , a cheap model or the Canon offering or maybe one of these.
Old 27-09-2006, 3:27 PM   #3
4,593, Level: 16
Points: 4,593, Level: 16 Points: 4,593, Level: 16 Points: 4,593, Level: 16
Thanks: Gave 16, Got 19
Re: remote control
Does that model work with the 300D?
I have the Canon RS-80N3, with my 20D. I find it very useful. It's simple but very effective.
Old 27-09-2006, 6:50 PM   #4
Conspicuous Member
Crocodile's Avatar
15,118, Level: 29
Points: 15,118, Level: 29 Points: 15,118, Level: 29 Points: 15,118, Level: 29
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 408, Got 1,147
Re: remote control
You could always use the self timer for landscapes (assuming the 350D has a self timer).
Old 27-09-2006, 10:00 PM   #5
tony79's Avatar
4,934, Level: 16
Activity: 3.4%
Re: remote control
are they the same connections for the 20d as the 350d or not??
Old 28-09-2006, 6:09 AM   #6
Kaoshan's Avatar
2,617, Level: 11
Re: remote control
No. The 350D uses a mini jack plug/socket for the remote control.
The 10D/20D/30D et al use a much larger three pin connector for the remote switch/control. See picture below...
Old 28-09-2006, 6:24 AM   #7
PaulBoy's Avatar
9,371, Level: 23
Points: 9,371, Level: 23 Points: 9,371, Level: 23 Points: 9,371, Level: 23
Thanks: Gave 58, Got 90
Re: remote control
tony79 - I was after something similar for my D200 & was advised this was a good one (there is also one for the 350D) albeit a bit expensive (!) Shipping is free though (?)
http://www.photo-scotland.co.uk/acat...e_Release.html
Never used the company before but they were good enough to contact me when they got some stock in - HTH ... Paul
tony79 (28-09-2006)
Old 28-09-2006, 7:24 AM   #8
h4rri's Avatar
7,667, Level: 20
Points: 7,667, Level: 20 Points: 7,667, Level: 20 Points: 7,667, Level: 20
Thanks: Gave 37, Got 173
Re: remote control
I use the RC-1 but that would be unsuitable as you need to be in front of the camera. Why they didn't reproduce the sensor on the back I don't know
Old 28-09-2006, 9:13 AM   #9
tony79's Avatar
4,934, Level: 16
Activity: 3.4%
Re: remote control
I know would have made sense but would also mean a lot of people not buying their expensive corded ones I suppose?!?!!?! So what is available from canon corded wise for the 350d? would like something that allows a fair bit of control
Old 28-09-2006, 9:39 AM   #10
Kaoshan's Avatar
2,617, Level: 11
Re: remote control
Tony79, if you look back at my original reply you will see I suggested three choices for your 350D, two corded and one wireless.
The Canon corded product is the RS-60E3. More sophisticated remotes for your camera do not seem to be available.
Old 28-09-2006, 9:47 AM   #11
tomson's Avatar
7,527, Level: 20
Points: 7,527, Level: 20 Points: 7,527, Level: 20 Points: 7,527, Level: 20
Thanks: Gave 88, Got 189
Re: remote control
I have a RS-60E3 at home - but no longer have a 350D. If anyone's interested i'll dig it out and put an ad in the classifieds.
Old 28-09-2006, 10:29 AM   #12
tony79's Avatar
4,934, Level: 16
Activity: 3.4%
Re: remote control
i did look at your reply koashan and thanks for the suggestions however I would prefer a canon one as Ive never heard of the make youve suggested. will check out the rs60 though!
Old 28-09-2006, 3:33 PM   #13
tony79's Avatar
4,934, Level: 16
Activity: 3.4%
Re: remote control
went and had a play in charles eagles with the rs60e3 seemed pretty good so have purchased it. thanks for all the advice
