As you want a DSLR, here's my 2p worth. Lots of people here have the Nikon D50 (under £500) or the Canon 350D (more expensive). There are new models coming out though, the Nikon D80 (I think that it's approx £800 so over budget) and the Canon 400D (again over budget). The new cameras may result in lower prices for the D50 and 350D though. Both are quality DSLRs and other posts have mentioned that you should handle them in a shop to see if they suit you (eg the Canon is smaller than the Nikon).
Personally, I was going to get a super-zoom (ie not a DSLR) but decided that a DSLR was more flexible and was going for the Nikon until I heard about the Pentax K100D, which I got primarily for the anti-shake feature and the ability to use old Pentax lenses. I like it and am happy, but you may feel that the others are better (eg they probably have more new lenses available etc).
I don't think that you will be disappointed with any of them.
They all come in kit form and so it's pretty cost-effective to get the kit rather than get the DSLR body and a different lens, as the kit lens adds little to the cost.
Also have a look at
http://www.dpreview.com and
http://www.steves-digicams.com/
Both sites have camera reviews and forums. Hopefully someone else in avforums will give you more info.
