HP R817 - solvable problem or replacement needed?
Old 30-07-2006, 8:39 PM   #1
mutamist's Avatar
5,560, Level: 17
Points: 5,560, Level: 17 Points: 5,560, Level: 17 Points: 5,560, Level: 17
Thanks: Gave 175, Got 80
I have been using a HP R817 for a few months which I bought because of the 5x optical zoom which was the best for a compact digital camera I could find at the time. Anyway, I took some photos at the zoo yesterday and I notice that there is a significant white glow around very white objects, as can be seen in this photo:
Is this a known problem with the HP R817 and is there an easy fix?
Otherwise, what are decent alternativs on the market? I'm after a small camera with a 5x or more optical zoom. I did see a small Kodak with a 10x optical zoom but there were bad reports about a lens jump and no image stabalisation, or something like that - I'm not very technical when it comes to cameras.
Any help would be appreciated, thanks.
Old 31-07-2006, 10:43 AM   #2
imcarm's Avatar
Thanks: Gave 174, Got 121
mutamist, was this taken with a flash? As it appears the flash on the HP R817 does apply some ghosting on images when used.
Info taken from here:
http://reviews.cnet.com/HP_Photosmar...0732158-6.html
Old 31-07-2006, 10:47 AM   #3
mutamist's Avatar
5,560, Level: 17
No, this was in broad daylight, though the same does happen when a flash is used too.
Thanks for the review link.
