Memory voltage - 400MHz DDR PC3200 - is 2.6V a problem when my motherboard says 2.5V?
Old 13-07-2006, 10:37 AM   #1
lmccauley's Avatar
9,661, Level: 23
Points: 9,661, Level: 23 Points: 9,661, Level: 23 Points: 9,661, Level: 23
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 155, Got 169
Question Memory voltage - 400MHz DDR PC3200 - is 2.6V a problem when my motherboard says 2.5V?
I'm looking to add some memory to my PC, as it slows right down using image manipulation software with 512Mb RAM.
My motherboard is a PC Chips M848 (AMD K7) which supports 3 X DDR333 or 2 X DDR400 1Gb 2.5V memory modules, according to the manual.
Unfortunately, all the DDR400 memory I have seen says 2.6V or 2.7V. Would it cause me a problem if I fitted 2.6V memory? I'm specifically looking at a Kingston 2GB kit (CL3, 2.6V - the CL2 stuff is 2.7V) for £120 from eBuyer.
Cheers,
Liam
Old 13-07-2006, 10:48 AM   #2
booyaka's Avatar
11,393, Level: 25
Points: 11,393, Level: 25 Points: 11,393, Level: 25 Points: 11,393, Level: 25
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 268, Got 679
should be fine - you can adjust the voltage in the bios screen on most computers these days.
Most other memory states 2.55V - 2.8V check out corsair, geil value memory which should also be fine.
lmccauley (13-07-2006)
