Originally Posted by Pirate!! Ahoy there! An extract from Cameras.co.uk. Seems like a false economy to me (sub £100), but you pays your money etc . . . I also ran a selection choice for anything up to £100 and it offered these: Digital Cameras Under £100 If you are looking for digital cameras under £100 there are a few points that you should be aware of. Obviously cameras in this price range are less expensive than many others. Therefore there will be a few areas where you are likely to see a bit less quality. The main differences your are likely to find if you are comparing these cameras with more expensive models are:
1. Less megapixels
2. No optical zoom lens - although you will find some cameras have them
3. Lower levels of build quality
4. Longer shutter lag or shutter delay 5. Higher battery consumption
In terms of picture quality you will probably notice a fall off in quality indoors, but you should be able to find digital cameras that can take good outdoor shots in this price range. |
link doesnt work mate
its a 5.1 megapixel camera
3x optical zoom and 5x digital zoom function. using both will offer a total zoom ratio of 15x
does this sound reasonable? im no good at this camera stuff
