oly e500 flashgun
Old 02-06-2006, 7:18 PM   #1
6,149, Level: 18
Points: 6,149, Level: 18 Points: 6,149, Level: 18 Points: 6,149, Level: 18
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 1, Got 9
oly e500 flashgun
i am about to buy a flash for my e500 and would like any input from owners of these guns? i am leaning towards the fl-36 which is about 130 quid,but i have read that the two AA batteries it takes soon loose power and recycle times are longish after short usage.
Or is the fl-50 worth paying double the price? i understand that they are exactly the same function wise, only the batteries (4) and the guide number (50) are different.
Or are any of the independants worth a look?
I will be using it for general photography,with maybe the very odd occasion needing the extra power.
Old 03-06-2006, 9:07 AM   #2
4,648, Level: 16
Points: 4,648, Level: 16 Points: 4,648, Level: 16 Points: 4,648, Level: 16
Thanks: Gave 95, Got 8
I have the Fl-36 which I use with my E1, and I would not recommend it based on my own experience.
The reason I bought it over the Fl-50 was because it was smaller, and I thought the GN difference would not be as large as it appears to be in use, however, I find the recycle times are poor, and whilst it is OK in most situations when used directly, when bounced it seems very underpowered. I also find the flash exposures sometimes inconsistent.
I can't compare it directly to the Fl-50 as I have not used it. I used to have a Canon 10D which I used with the Speedlite 550ex, which was brilliant, very powerfull, quick to recharge and very accurate. I would not buy an Fl-36 again, and would probably try the Fl-50, however I suppose it really depends what you want to use it for, and what your expectations are.
If you can you should find a shop that has both and try them for yourself
Old 03-06-2006, 9:03 PM   #3
6,149, Level: 18
Activity: 1.4%
thanks julisinar,what sort of distances is the fl 36 good for in actual use.
