Zoom/Macro Lens Advice
Old 12-05-2006, 5:52 PM   #1
2,695, Level: 12
Points: 2,695, Level: 12 Points: 2,695, Level: 12 Points: 2,695, Level: 12
Thanks: Gave 8, Got 1
I currently have a a 350D with the kit lens and the 50 mm 1.8. I am looking into getting a lens with a better zoom and preferably the ability to take decent macro pictures. I have about £150 - £200 to spend and have the canon rebate vouchers. I was looking at the following lenses:-
Sigma 70-300mm F4-5.6 APO DG Macro
Sigma 28-300mm f3.5-6.3 Compact Asph Hyperzoom AF Zoom Lens
Canon EF 90-300mm f4-5.6 USM LENS
What are peoples thoughts on these lenses?
Also what is the advantages of getting a lens with a wider range of zoom (i.e 70-300, 28-300, 90-300)?
What are the advantages of getting a prime macro lens over a zoom lens with macro ability? Can you us a prime macro lens for other types of photograph?
Sorry for all the questions and thanks for any advice you can give.
Old 12-05-2006, 10:41 PM   #2
3,729, Level: 14
Points: 3,729, Level: 14 Points: 3,729, Level: 14 Points: 3,729, Level: 14
Thanks: Gave 6, Got 36
These aren't real "macro" (they are not 1:1). The extreme close-ups of bugs and things are done with real macro lenses, like the Canon EF-S 60mm macro and 100mm (there's also Tamron/Sigma).
So it really depends, do you want zoom or macro only?
K.
Old 13-05-2006, 9:51 PM   #3
2,695, Level: 12
Well ideally I want a reasonable quality of zoom lens with the ability to try macro photography as I couldn't really justify buying a lens to take macro photography at the moment.
Hope that helps.
Any more advice?
Old 13-05-2006, 10:18 PM   #4
45,504, Level: 52
Points: 45,504, Level: 52 Points: 45,504, Level: 52 Points: 45,504, Level: 52
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 378, Got 854
the sigma 70-300 gets recommendations as a solid zoom in general (especially the APO version), with the benefit of an 'almost' macro mode built in - 1:2 magnification rather than 1:1 you normally get with proper macro lenses.
Its a good option.
Old 14-05-2006, 8:10 AM   #5
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Sigma produce an APO close-up filter for the 70-300mm which makes it full 1:1 (slightly more with crop factor cameras). I use the 70-300mm and it's a great all-rounder lens for the price.
