Originally Posted by SeaneyC I'm slightly confused as to why you're using RSMMC cards in the Jam, as it has a full size SD slot..... maybe you got a good deal on them i'm thinking?
But anyway, your Imate and Camera will BOTH take SD cards, and you would be best off buying full size SD cards as IMHO SD cards are quicker, more reliable, and sturdier. |
Thanks for this info very helpful, I bought them in India for a fiver each. I thought they were the only ones I could use, I should have researched a bit more into this before splashing my cash or even read the manual properly
. Anyhows thanks once again
