Any Compact camera with RAW?
Old 30-04-2006, 9:10 AM   #1
3,343, Level: 13
Points: 3,343, Level: 13 Points: 3,343, Level: 13 Points: 3,343, Level: 13
Thanks: Gave 8, Got 7
I'm looking for a new digicam. There I was, all set for the fuji s9500 when I heard a voice behind me. "You're not buying a camera that big are you?" After some discussion, 'I' have decided to look down the compact route. Cost is not a real concern but image quality is. I would really like to capture RAW files. Anyone recommend something?
Thanks in advance.
Old 30-04-2006, 9:14 AM   #2
4,594, Level: 16
Points: 4,594, Level: 16 Points: 4,594, Level: 16 Points: 4,594, Level: 16
Thanks: Gave 1, Got 9
Well, the S5600 (S5200 elsewhere) is smaller and cheaper, and supports RAW.
Old 30-04-2006, 9:17 AM   #3
3,343, Level: 13
Still too big!
Old 30-04-2006, 11:11 AM   #4
Ray Ray is offline
Ray's Avatar
5,662, Level: 17
Points: 5,662, Level: 17 Points: 5,662, Level: 17 Points: 5,662, Level: 17
Thanks: Gave 48, Got 24
We use a G6 at work and that records RAW . Maybe the other Powershot ones do as well.
http://consumer.usa.canon.com/ir/con...categoryid=113
Ray
Old 30-04-2006, 5:19 PM   #5
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Ray
Yes they do but support for their RAW with Photoshop ( and Elements) is not universal. This is not really a problem as RawShooters Essentials 2006 is freely available ( for now )
The Powershot Pro one is particularly well featured but Im not sure I'd call it a "compact" with its 28-200mm L lens! but PQ is not in doubt
Old 30-04-2006, 5:47 PM   #6
4,321, Level: 15
Points: 4,321, Level: 15 Points: 4,321, Level: 15 Points: 4,321, Level: 15
Thanks: Gave 54, Got 43
Canon Powershot S80 would be good, else the S70 can also still be had if you shop around you may get it at a good price.
Old 30-04-2006, 5:52 PM   #7
11,652, Level: 25
Points: 11,652, Level: 25 Points: 11,652, Level: 25 Points: 11,652, Level: 25
Thanks: Gave 63, Got 107
I think the Fuji FinePix E900 offers RAW processing.
Old 30-04-2006, 9:30 PM   #8
3,343, Level: 13
Thanks for your time guys. I've decided to skip RAW and go for a Canon ixus 750.
Old 01-05-2006, 5:53 AM   #9
47,154, Level: 53
Activity: 2.7%
Happy shooting with it m8
When you later decide to get RAW, bear in mind it adds one more step to post processing on the computer but potentially helps you get the best possible recorded image from your camera.
Im not sure of the compacts but on the Canon 350D you can get RAW and Jpeg: If you feel the jpeg is fab you can simply forget the RAW
Old 01-05-2006, 8:14 AM   #10
3,343, Level: 13
My decision was eventually based on the size and age of the camera. The s80 canon doesn't have RAW, the s70 canon does but the camer is over two years old. The camera will be used indoors alot and everything I've read suggests the 750 performs well in low light. I'll have it soon so we'll see.
