Prime lens advice
Old 28-04-2006, 10:48 AM   #1
Magslad's Avatar
4,732, Level: 16
Points: 4,732, Level: 16 Points: 4,732, Level: 16 Points: 4,732, Level: 16
Thanks: Gave 145, Got 147
Prime lens advice
So I'm now completely bitten by the DSLR bug, having had my D50 for 4 months: due in no small part to these forums (thanks folks )
Now that I can't bear to be without my camera, I've decided it's time to invest in a 50mm prime lens, so really looking for some advice from forum members or any experience you have using 50mm Nikon-mount primes. I'd certainly consider other makes (Sigma/Tamron) as well as Nikon, and probably initial budget £200-300 but willing to push it higher if it's going to make a difference as I want this lens to last for a bit so don't really want 'entry-level' quality.
Thanks in advance for any help you can give.
NB I'll probably be back in a few weeks for advice on telephoto lenses: I've got the 55-200mm AF-S Nikon G series as it was on a cheap deal, but not sure it performs especially well at the upper reaches so will probably look to upgrade, this was an impulse buy and a bit of a mistake with hindsight. But think I'll concentrate on getting a good prime first.
Old 28-04-2006, 11:32 AM   #2
Zone's Avatar
42,826, Level: 50
Points: 42,826, Level: 50 Points: 42,826, Level: 50 Points: 42,826, Level: 50
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
Thanks: Gave 490, Got 900
Stick with Nikon and get the 50mm 1.8D AF, its as well regarded by Nikonians as the the Canon nifty fifty.
Microglobe have it at £79 here
Magslad (28-04-2006)
Old 28-04-2006, 3:10 PM   #3
Radiohead's Avatar
15,086, Level: 29
Points: 15,086, Level: 29 Points: 15,086, Level: 29 Points: 15,086, Level: 29
Thanks: Gave 327, Got 450
Also consider the Nikkor 35/2 and 85/1.8's as alternatives, alongside a mint, used 50/1.4.
Old 28-04-2006, 4:11 PM   #4
Magslad's Avatar
4,732, Level: 16
Thanks for this Zone, looks a very good price. Have you used Microglobe before, are they reliable etc?
Magslad
Old 28-04-2006, 4:51 PM   #5
Zone's Avatar
42,826, Level: 50
Activity: 10.6%
Not personally but a friend has a few times now buying second hand stuff and he's never had a problem, they also have a highstreet presence on Oxford Street as well if you're London based.
Old 28-04-2006, 6:55 PM   #6
Magslad's Avatar
4,732, Level: 16
Thanks again Zone. I work in London so I may well have to pop in there next week.
Old 28-04-2006, 7:11 PM   #7
Zone's Avatar
42,826, Level: 50
Activity: 10.6%
Your wlcome mate and apparenlty they are also pretty responsive to a little bit of haggling (if its 2nd hand) so
