Any quick release neck strap devices out there ?
Old 02-04-2006, 10:08 PM   #1
RimBlock's Avatar
5,895, Level: 18
Points: 5,895, Level: 18 Points: 5,895, Level: 18 Points: 5,895, Level: 18
Thanks: Gave 7, Got 16
I hate having the neck strap on the camera.
When ever I need to take a shot the strap always seems to get in the way so is there any quck release devices to allow you to quickly remove the neck strap and reattach it as required ?
If not my only thoughts are getting some of the strap material and making loops through the anchor points on the camera. Then making loops on the neck strap and linking the two sets of loops with mini carabiners.
The camera will have the hand strap on it anyway.
Any thoughts or suggestions ?
Rb
Old 03-04-2006, 5:29 AM   #2
jtgraphics
Posts: n/a
The PRO LOOP STRAP by OP/TECH USA are what I like even with heavy loads it the best I've used.
http://www.optechusa.com/product/det...RODUCT_SUB_ID=
Old 03-04-2006, 4:42 PM   #3
RimBlock's Avatar
5,895, Level: 18
Thanks JT,
That is the kind of thing I was looking for. There are a few suppliers in the UK too.
Not too pricey either.
RB
Old 04-04-2006, 1:11 PM   #4
kez kez is offline
kez's Avatar
5,395, Level: 17
Points: 5,395, Level: 17 Points: 5,395, Level: 17 Points: 5,395, Level: 17
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 531, Got 387
another op/tech user here.
wonder if they do guitar straps?
Old 04-04-2006, 4:34 PM   #5
Gadfium's Avatar
7,553, Level: 20
Points: 7,553, Level: 20 Points: 7,553, Level: 20 Points: 7,553, Level: 20
Thanks: Gave 39, Got 11
I have received the Optech from Warehouse Express..went for the classic one. The strap is soooo much more comfortable than the Canon item, as it is made from neoprene and quite "stretchy".
The only negative that I would have is that the bits that connect to the camera are quite long, so you still have "danglies" hanging off the camera....
Old 04-04-2006, 10:05 PM   #6
RimBlock's Avatar
5,895, Level: 18
Thanks to all .
I have put in an order for one of the pro loop straps.
Hopefully it will arrive in the next two days
RB
Old 05-04-2006, 2:46 PM   #7
3,815, Level: 14
Points: 3,815, Level: 14 Points: 3,815, Level: 14 Points: 3,815, Level: 14
Thanks: Gave 7, Got 19
RB
Where would that be? - I'm looking for one of these myself...
Old 05-04-2006, 4:25 PM   #8
kez kez is offline
kez's Avatar
5,395, Level: 17
Activity: 2.0%
http://www.optechusa.com/distributors/international/uk/
warehouse express and optech's own online store spring to mind
Old 05-04-2006, 11:21 PM   #9
RimBlock's Avatar
5,895, Level: 18
I ordered from camera err something......
Based in London. They also had a speedlight 580EX for £2xx rather than over £300 at most places.
If you go to optitec's site and click 'where to buy' -> international suppliers -> click UK flag and they are listed. THere are only 4 or 5 listed so it should be obvious.
Regards
RB
Old 06-04-2006, 1:26 PM   #10
kez kez is offline
kez's Avatar
5,395, Level: 17
Activity: 2.0%
or, click the link in the psot above yours
Old 06-04-2006, 4:42 PM   #11
RimBlock's Avatar
5,895, Level: 18
See what happens when you browse at home in the morning and reply when you get home without refreshing .
Some people may like the adventure of following the instructions and discovering the location for themselves while admiring the wonders they can see along the way .
Ok, maybe not but it was worth a try
RB
Old 06-04-2006, 7:18 PM   #12
kez kez is offline
kez's Avatar
5,395, Level: 17
Activity: 2.0%
