Originally Posted by FeiJi Fancier Interesting, not being a photography expert (just an educated point and shooter really), I'd not really considered the thought that lens reach might be anything other than 15 times closer than no zoom at all.
Am I right in believing that what you're saying is that this camera (the Pro815) starts with a wider angle view than most, and therefore the lens may be more flexible than many, giving it good telephoto reach, but a noticeably better wide angle starting point with no zoom applied? |
Yep, the zoom figure 8x, 10x , 12x or whatever just describes the focal length coverage of the lens, not how much closer the subject will be in the final image compared to your standard view of it (by which i mean your naked eye or about 50mm focal length in 35mm film equivillant).
If you are buying a camera for it's telephoto capabilities, always look at the quoted 35mm equivillant figure for the lens, not the zoom figure like 10x.
15x is quite dramatic coverage, giving a good spread from genuine wide angle to good telephoto... but there's often an optical compromise with increased zoom coverage.
