Panasonic FZ5 extra batteries & accesories
Old 07-09-2005, 11:15 AM   #1
Conspicuous Member
kbfern's Avatar
28,004, Level: 40
Points: 28,004, Level: 40 Points: 28,004, Level: 40 Points: 28,004, Level: 40
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 408, Got 1,142
Just got a Panny FZ5 and was going to get an extra battery jessops wanted £29 + £29 for the car charger.
I just looked on e-bay and somone from Hong Kong is selling 2 batteries (same code number and rating as pannys) + a car charger for £12.89 + £7.50 shipping.
Also may consider Tele converter and wide angle lenses also available on e-bay.
Does anyone have any experience with 3rd party batteries and lenses for any of the panasonic range of cameras off e-bay?
Old 07-09-2005, 12:34 PM   #2
RobertP's Avatar
4,800, Level: 16
Points: 4,800, Level: 16 Points: 4,800, Level: 16 Points: 4,800, Level: 16
I have ebay hong kong batteries and a charger for my Canon. Charger is fine and batteries outlast the Canon original.
Old 07-09-2005, 1:24 PM   #3
Conspicuous Member
kbfern's Avatar
28,004, Level: 40
Activity: 31.8%
Thanx RobertP looks like I will order some in the next few days and save myself a bundle.
Old 08-09-2005, 7:25 PM   #4
6,704, Level: 19
Points: 6,704, Level: 19 Points: 6,704, Level: 19 Points: 6,704, Level: 19
Thanks: Gave 0, Got 6
I have got the 2 batteries and car charger from ebay - seem fine, and quick shipping.
HOWEVER, avoid the add on lens from what I have read. Loads of bad reviews - they may fit, but that is about all they do!
I got an Oly a200 1.5x tele lens for my FZ5, plus a Raynox DCR720 wide angle - not bad, but lots of other options available.
Old 08-09-2005, 8:07 PM   #5
Conspicuous Member
kbfern's Avatar
28,004, Level: 40
Activity: 31.8%
Thanks father, will order some batteries and look around more at lens options.
How much were the lenses you bought and from where?
Old 08-09-2005, 10:43 PM   #6
6,704, Level: 19
the a200 was an ebay job (£50), as no longer made.
The raynox dcr720 was a cheapy from Jessops (£30), but does a reasonable job - some barrel distortion, and a tiny bit of vignetting, but not too bad.
Two good sites for camera stuff are stevesforums
and dpreview
links are to a couple of threads on add on lens. Lots more around!
Ali
