Help with downloading RAW please
Old 08-08-2005, 9:59 PM   #1
5,643, Level: 17
Points: 5,643, Level: 17 Points: 5,643, Level: 17 Points: 5,643, Level: 17
Thanks: Gave 0, Got 2
Can anybody help me with downloading RAW images please. I am not very computer literate so I will explain that which has happened so far.
Having taken about seven or eight RAW piccies I then connected my 20D to my computer. The message came up that there were no pictures in the camera. On advice I then bought a card reader. I have since inserted the Microdrive into the card reader and instead of images I get a Windows box with all of the images in it but not as pictures.
I just get a rectangular box with the image number next to it and the size of the image in kB.
Any help would be much appreciated.
Old 08-08-2005, 10:15 PM   #2
RobertP's Avatar
4,800, Level: 16
Points: 4,800, Level: 16 Points: 4,800, Level: 16 Points: 4,800, Level: 16
Thanks: Gave 1, Got 0
When I plug my card into the reader a window opens on screen with options asking what I want to do. I choose 'open folder to view files using windows explorer' .
That then shows me the files on the card. I double click through the folders until I see the picture files (something.jpg) or the RAW files (something.CR2 in my case). I select all the files and then 'cut' them.
Now I use another explorer window and make a new folder on the hard drive where I want the files... go into that folder and 'paste' the files in from the card.
I have my explorer window view settings to 'details' so I do not see thumbnails of pictures normally.I also have it set to show file extensions (the .jpg or .CR2 bit). Whatever your view preferences the principle is the same.
There is an add on to windows to see thumbnails of raw files in windows explorer etc. Without that you will just see file names.
Once the files are on the hard drive you can open them with whatever program you use for RAW processing.
Old 09-08-2005, 8:21 AM   #3
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
If you're using Windows XP then you'll find it here:
http://www.microsoft.com/downloads/d...DisplayLang=en
I'm not sure if it's available for other versions of Windows though.
Old 09-08-2005, 2:41 PM   #4
7,751, Level: 21
Points: 7,751, Level: 21 Points: 7,751, Level: 21 Points: 7,751, Level: 21
Thanks: Gave 1, Got 6
I really don't think there's any excuse not to be using XP at this point in time. It's 2005 for christs sake, it's been out for about 4-5 years, the next OS is only a stones throw away!
Old 09-08-2005, 9:38 PM   #5
5,643, Level: 17
Thank you everybody. I have downloaded the Rawviewersetup.exe and will try again.
Thank you again.
Old 12-08-2005, 12:05 AM   #6
longleyc
Posts: n/a
Rtfm
RTFM and load the software.
You need the manufacturers raw file reader to open/adjust raw files.
If you have Photoshop CS then that will read a lot of raw files if you check for upgrades.
Old 13-08-2005, 12:01 AM   #7
5,643, Level: 17
I did as TOMATO1 suggested and sure enough there is a free download of Raw Viewer available from Microsoft.
Using this software and a card reader I was able to see the RAW images that I had shot earlier. Unfortunately, as the file title implies, it was to view the images only and I could not fiddle with them.
Thank you everybody anyway. The learning curve continues !
Old 13-08-2005, 1:15 PM   #8
DigiDunk
Posts: n/a
20D raw conversion
Hi, You should try installing the software that comes with the Canon 20D. Then go here http://software.canon-europe.com/Cam...S_20D10131.asp and install the updates. You could search google for Canon Raw convertor
Old 13-08-2005, 1:39 PM   #9
mr jones's Avatar
9,523, Level: 23
Points: 9,523, Level: 23 Points: 9,523, Level: 23 Points: 9,523, Level: 23
Thanks: Gave 6, Got 22
im on xp, however windows 2000 is a better and more stable operating system. ive not upgraded to SP1 or SP2 (serious problems upgrades) networks etc are another reason for not having XP
Old 13-08-2005, 1:40 PM   #10
mr jones's Avatar
9,523, Level: 23
try rawshooter essentials from pixmantec http://www.pixmantec.com
its free and much better than the canon software
Old 13-08-2005, 2:26 PM   #11
DigiDunk
Posts: n/a
Rawshooter Essentials
This looks like only a trial version is that correct ?
Old 13-08-2005, 2:42 PM   #12
mr jones's Avatar
9,523, Level: 23
for some reason it says its a trial version but there is nothing in the program to make me think its a trial version, its fully functional and doesnt have any time limit on it
