| Unsharp Mask Settings....
So, just wondering what Unshark Mask settings we all use in PS
Some examples below from my fellow aircraft photogs ..
I currently use the first suggestion..
Granite (Gary Watt) gave me an excellent USM setting of 500% , 0.2 , 0
I hit it with that for a first go.... Then reduce the % for the next sweep depending on the sharpness or jaggies. Normally between 100-300%. Normally 2 x 500% is to much...
In my case it seems to work very well...
Simon C
I've had two badsoft today, my first in ages but I use a method that a screener advised me to try and it had worked most of the time....until today.
The rejected ones, the screeners were right, they were soft and I have been scanning some more oldies and I think I might have left the threshold at 7 in error!
I Use 200% 0.3, 2, then 200% 0.2,2, and, if it will stand it 200%, 0.2, 2 again (most don't)
This works but goes against what Adobe say...they say make one sweep and get it right first time as any subsequent sharpening is performed differently.
If I get Badsoft I re-open the image in LAB mode, select the lightness channel, increase the contrast a touch if the pic can take it then add USM 200%, 0.2, 2 before converting back to RGB.
That usually works for me
Mick Bajcar
hehe
500%, .5 Radius, 5 Levels.
100% acceptance on last batch.
For sharpening I first resize the picture to desired size and then set radius to
0.2 pixels and threshold to 0. Then I adjust the amount to desired setting. I find that 3 applications of amount 100% gives better results than 1 application of amount 300%.
Simon,
Change the image to Lab mode and then click on the lightness channel, then start at a USM of 300, 0.3, 0 and go from there. Then change it back to RGB to finish.
This shouldn't introduce any unwanted noise within the sky etc.
Hope this is of some use, if you need any help drop me a mail.
Cheers,
Ian.
Wow, very different stuff here.
I do radius o .2, threshold of 0. I do one pass at 500 and then a second at anywehre from 110 ro 350.
-Phil
