converting old photos
Old 28-12-2004, 7:56 AM   #1
carl310166
Posts: n/a
What is the easiest way to convert all my old photos to the digital format?
I have read a few reviews on the hp scanjet 5530 autofeed scanner,but they seem to jam etc.
Is there another way,other than scanning every photo individually?
Does the speed of scanners differ much? are the expensive ones very much faster?
Any help would be appreciated.
Old 30-12-2004, 1:35 PM   #2
mr jones's Avatar
9,523, Level: 23
Points: 9,523, Level: 23 Points: 9,523, Level: 23 Points: 9,523, Level: 23
Thanks: Gave 6, Got 22
you can get negative scanners, but they're no use unless you've got the negatives!
Old 30-12-2004, 7:14 PM   #3
Conspicuous Member
witters's Avatar
20,307, Level: 34
Points: 20,307, Level: 34 Points: 20,307, Level: 34 Points: 20,307, Level: 34
Thanks: Gave 383, Got 139
I used a Canon 9000 scanner. I had hundreds of "old" prints and it took ages. Quality was good though once they were done. The Canon also comes with a slide/negative attachment.
Old 31-12-2004, 7:37 AM   #4
carl310166
Posts: n/a
Thanks guys,i just thought there might be an easy way of doing it.
witters,do you do evey photo individually? as i have seen a canon scanner that can multi scan,whatever that means?
Old 31-12-2004, 9:40 AM   #5
Conspicuous Member
witters's Avatar
20,307, Level: 34
I did them all seperately - over 2,000......
Old 31-12-2004, 10:50 AM   #6
6,658, Level: 19
Points: 6,658, Level: 19 Points: 6,658, Level: 19 Points: 6,658, Level: 19
Are any of these scanners also capable of reading APS cartridges?
Old 31-12-2004, 2:00 PM   #7
DJW DJW is offline
13,062, Level: 27
Points: 13,062, Level: 27 Points: 13,062, Level: 27 Points: 13,062, Level: 27
Jesus . You're mad
Old 02-01-2005, 9:31 PM   #8
Johndm's Avatar
11,419, Level: 25
Points: 11,419, Level: 25 Points: 11,419, Level: 25 Points: 11,419, Level: 25
Thanks: Gave 33, Got 46
Originally Posted by DJW
Jesus . You're mad
You think hes mad....... I've got about 2000 slides to scan..
At least the dedicated slide/negative scanner I got will do 4 at a time..
Old 04-01-2005, 12:42 PM   #9
3,347, Level: 13
Points: 3,347, Level: 13 Points: 3,347, Level: 13 Points: 3,347, Level: 13
Thanks: Gave 1, Got 3
Just ordered a minolta neg/slide scanner for this purpose, seems like a fairly compact machine so can leave it out on desktop and just scan in when time permits instead of doing them all in one go. I can see this getting used extensively (family,friends etc) so only time will tell if this comparitively cheap scanner will last the course but reviews are favorable.
review link: review link:
The cheapest place I found this was surprisingly Jessops! (£219 inc free shipping)
Oh and there is an optional APS adapter available too but at an extra £75
Old 04-01-2005, 4:38 PM   #10
Johndm's Avatar
11,419, Level: 25
My TAMRACK / JENOPTIK ARTISCAN 2400 FILM SCANNER was just £49 from Ebay...brand new too..
I don't think you should keep it on your desk, as they can suffer from dust.
It is quite hard to clean them out apparently..
regards
