Yeah in good light
£350 was more than my first dslr I brought a used Nikon d40.
Then from memory that with kit lens, indoors low lighting without flash it wouldn't cope, although a wicked body in size, function and feel. Would definitely recommend one to those wanting a cheap entry level used option dslr
However back on topic, is it worth the £350. Well if you want one of the best compacts which would fit I small pockets this would be the one
However lx5 and xz1 is suppose to be good, although looking on YouTube clip a few pics showed s100 pics being better. Although surely the f1.8 would / could play advantage
I'm not techie enough to balance all the pro and con but the s100 does have a CMOS sensor with awesome 8/9 frames per second!
