3D Color Management/Calibration (Monitor/Display)
Old 05-11-2009, 4:06 PM   #1
Nielo TM's Avatar
20,475, Level: 34
Points: 20,475, Level: 34 Points: 20,475, Level: 34 Points: 20,475, Level: 34
Thanks: Gave 56, Got 572
Arrow 3D Color Management/Calibration (Monitor/Display)
Does anyone here aware of any calibration software (for Win Vista) capable of calibrating both 2D grayscale and 3D color (and also compatible with DTP-94 colorimeter)?
I've tried basICColor and ColorEyes display pro but they only calibrate 2D grayscale.
DispcalGUI has option for Rec. 709, but I can't get the program to work.
Old 11-11-2009, 2:46 PM   #2
1,049, Level: 7
Points: 1,049, Level: 7 Points: 1,049, Level: 7 Points: 1,049, Level: 7
Thanks: Gave 19, Got 26
Re: 3D Color Management/Calibration (Monitor/Display)
Can I ask what it is you're trying to calibrate? (I guess a HDTV if you're talking of REC.709)?
Old 11-11-2009, 6:32 PM   #3
Nielo TM's Avatar
20,475, Level: 34
A monitor to Rec. 709 specs
Or to sRGB gamut with D65 white point and gamma of 2.2
Old 11-11-2009, 6:54 PM   #4
1,049, Level: 7
Can you be a bit more specific as to the monitor in question?
Old 11-11-2009, 7:22 PM   #5
Nielo TM's Avatar
20,475, Level: 34
Dell 2209WA with e-IPS panel via DVI with DDC enabled.
It has an option to control the usual RGB levels, like most monitors, it doesn't have CMS.
Old 11-11-2009, 8:53 PM   #6
1,049, Level: 7
Okay, well I wouldn't bother with REC 709 unless you have a monitor that would particularly benefit from it, and I don't think any desktop monitor can.
I'm no expert as far as TV calibration is concerned but I'd imagine that REC 709 might well be a specific tone curve for broadcast displays - I'll have to check up on that.
Basiccolor Display is very good as it allows you to set an 'exact' curve for sRGB rather than the very near gamma of 2.2 and it's compatible with the DTP-94.
I presume then that you're after editing video?
Old 11-11-2009, 9:18 PM   #7
Nielo TM's Avatar
20,475, Level: 34
Yes and to use a reference display
When I calibrate HDTVs to the Rec. 709 spec, the difference between it and the Dell is quite significant. So it's best to have a display to compare the accuracy to.
I also need for editing and authoring videos.
TBH, I don't why the Dell can't support Rec. 709. After all, its gamut is very close.
PS: What did you meant by "exact curve for sRGB"?
Old 12-11-2009, 8:27 AM   #8
1,049, Level: 7
Originally Posted by Nielo TM View Post
[B][COLOR="Gray"]
The tone response curve for the sRGB colour space is not quite the same as a gamma of 2.2. Essentially the TRC is is a way of describing (and editing) the range of luminosity in a given scene against what you would eventually see in print - or in your case film. (I'm not very good at technical explanations)
I would imagine that you'd have difficulty in accurately matching a desktop monitor to a hdtv simply because hdtv's have all those different settings for making the picture look better.
I have to leave for work but I'll come back to this a bit later if that's okay
Old 14-11-2009, 12:12 AM   #9
Nielo TM's Avatar
20,475, Level: 34
I see
After spending few more times Googling, it would seem that there is not such software.
I would have to buy a monitor that supports Rec .709 natively or a HDTV with accurate CMS.
I'll try and use the L curve instead of 2.2
