Recommendation for a Tripod
Old 30-09-2009, 1:24 PM   #1
16,086, Level: 30
Points: 16,086, Level: 30 Points: 16,086, Level: 30 Points: 16,086, Level: 30
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 402, Got 125
I currently have a cheap £20 jessops tripod which is ok and I fancied trying to get a decent one. I would really like one that is solid, light, folds away into a small space.
I did see this one in my local photo shop and it seems to do the ticket:
Vanguard Alta+ 204AP*
Vanguard GB
Amazon have it for £75 :
Vanguard Alta 204AP Tripod with PH-12 Panhead: Amazon.co.uk: Electronics & Photo
The above one is a 4-Section tripod which I like as it folds away very small.
Anyone recommend a smallish tripod that extends into a decent height tripod for around the £100ish mark ?
EDIT: Just seen this:
Manfrotto 785B Modo Maxi Tripod for £45 which looks neat:
http://www.warehouseexpress.com/buy-...ripod/p1014517
Old 30-09-2009, 3:39 PM   #2
4,144, Level: 15
Points: 4,144, Level: 15 Points: 4,144, Level: 15 Points: 4,144, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 3, Got 29
Re: Recommendation for a Tripod
When i was looking everyone kept suggesting these.
Red Snapper | RS-283 and RSH-12 ball head
mark.carline (30-09-2009)
Old 30-09-2009, 3:50 PM   #3
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Or the RedSnapper 284 (4 section) tripod which folds up smaller, but is less sturdy than a 3 section tripod of course.
I have the 283 tripod and RSH 12 ballhead.
You could actually try doing a forum search as well. Amazing what this simple facility can throw out in terms of results.
