85mm f1.4 on D700 or 50mm f1.4 on D300
Old 28-09-2009, 5:12 PM   #1
5,571, Level: 17
Points: 5,571, Level: 17 Points: 5,571, Level: 17 Points: 5,571, Level: 17
Thanks: Gave 19, Got 10
Hi everybody,
I own a D700 and had been thinking of getting the Nikon 85mm f1.4 D but at £880 its a lot of dough.
I could get a D300 and use my 50mm f1.4 which would be equivalent to a 75mm f1.4 using the 1.5 crop factor of the DX sensor.
I'd also have a second body for non-repeatibe events.
Does my logic make sense? Have I missed something? Am I miss-understanding focal lengths, DOF and crop factors.
Any feed back would be greatly appreciated
Ta
Litch
Old 28-09-2009, 5:33 PM   #2
johnaalex's Avatar
22,591, Level: 36
Points: 22,591, Level: 36 Points: 22,591, Level: 36 Points: 22,591, Level: 36
Activity: 8.7%
Activity: 8.7% Activity: 8.7% Activity: 8.7%
Thanks: Gave 560, Got 1,186
Re: 85mm f1.4 on D700 or 50mm f1.4 on D300
Can't fault your maths. As an owner of both a 50 and 85 1.4 there is little between them when it comes to IQ. The 85 is quite a bit bigger and heavier than the 50 and those factors maybe something else you want to consider if you will be lugging two cameras around.
Litch (28-09-2009)
Old 28-09-2009, 7:06 PM   #3
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Logic makes perfect sense
Litch (28-09-2009)
Old 28-09-2009, 9:46 PM   #4
Illustrious Member
sdb123's Avatar
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
Having owned both a Sigma 50mm f/1.4 and a Nikon 85mm f/1.4 with a D700 (now a D300), the 85mm really comes into its own on Full-Frame IMO. Those two focal lengths are lovely on FF....personally I'd go for the lens rather than the 2nd body.
Litch (30-09-2009)
Old 30-09-2009, 10:48 AM   #5
5,571, Level: 17
Firstly thanks for the responses chaps
I decide to go with the lens purchase in the end.
My rational was that good glass last a lot longer that a body.
The lens arrived yesturday, thanks to warehouse express's uber quick delivery
There's a few quick shots on my flickr stream if anyones interested.
Thanks again,
Litch
Old 30-09-2009, 11:26 AM   #6
18,258, Level: 32
Points: 18,258, Level: 32 Points: 18,258, Level: 32 Points: 18,258, Level: 32
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 1,222, Got 1,374
Litch
Seems to be less depreciation as well, a good choice imo.
