Digital Camera for girlfriend
Old 28-07-2009, 7:50 PM   #1
paul cliff's Avatar
2,285, Level: 11
Points: 2,285, Level: 11 Points: 2,285, Level: 11 Points: 2,285, Level: 11
Thanks: Gave 9, Got 19
Hi, need some help here, my gf is after a new digital camera, she has narrowed it down to these two: Compare Best Digital Cameras by Features, Price & Reviews | Comet
which should she go for and why?? thanks in advance.
Old 28-07-2009, 9:19 PM   #2
solidamber's Avatar
3,782, Level: 14
Points: 3,782, Level: 14 Points: 3,782, Level: 14 Points: 3,782, Level: 14
Thanks: Gave 44, Got 116
Re: Digital Camera for girlfriend
One thing to note about the sony is that it only takes its own type of memory cards which are quite expensive.
Old 28-07-2009, 9:27 PM   #3
paul cliff's Avatar
2,285, Level: 11
thanks for the heads-up.
I'll let her know before she buys.
Old 29-07-2009, 9:14 AM   #4
paul cliff's Avatar
2,285, Level: 11
not much luck here then, any suggestions where else I could ask?
I think she's going to get the Pentax anyway.
Old 29-07-2009, 9:55 AM   #5
Jammyb's Avatar
8,302, Level: 21
Points: 8,302, Level: 21 Points: 8,302, Level: 21 Points: 8,302, Level: 21
Activity: 26.9%
Activity: 26.9% Activity: 26.9% Activity: 26.9%
Thanks: Gave 47, Got 322
It's because it looks like you've just picked the two bestsellers at Comet and then asked which we'd buy. I probably wouldn't buy either.
But if you said you had a budget of X and what you planned to use the camera for and size constraints etc, you'd probably get more responses.
Personally I'd get a Panasonic or a Canon in the sub £200 compact range.
Old 29-07-2009, 12:23 PM   #6
20,062, Level: 34
Points: 20,062, Level: 34 Points: 20,062, Level: 34 Points: 20,062, Level: 34
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 323, Got 685
How careful is your girlfriend? If she's anything like mine, i'd spend a bit more and get a Olympus Mju Tough; waterproof to 10m, meant to be able to withstand knocks/drops/shock, full-auto one-press-for-idiots
EDIT: Scratch that, looks like the Canon D10 is arguably better, but the Panasonic DMC-FT1 takes better pictures and takes 720p video. Choices...?
Old 29-07-2009, 3:18 PM   #7
GJC GJC is offline
GJC's Avatar
7,417, Level: 20
Points: 7,417, Level: 20 Points: 7,417, Level: 20 Points: 7,417, Level: 20
Thanks: Gave 104, Got 43
Not sure how much these cost but the new Panasonic DMC FX60 in Pink might be worth a look.
Old 29-07-2009, 9:40 PM   #8
paul cliff's Avatar
2,285, Level: 11
Thanks for the replies.
Little more info here, she has a budget of £100-£120
Old 30-07-2009, 9:02 PM   #9
paul cliff's Avatar
2,285, Level: 11
Old 02-08-2009, 1:24 PM   #10
solidamber's Avatar
3,782, Level: 14
I agree I would not buy eather one, My prefered compact brands are in order
Canon, panasonic,Fuji
