CS3 Tools problem
Old 09-07-2009, 6:59 PM   #1
1,888, Level: 10
Points: 1,888, Level: 10 Points: 1,888, Level: 10 Points: 1,888, Level: 10
Thanks: Gave 81, Got 9
CS3 Tools problem
Hi guys
Have a problem in CS3 I would appreciate help with. I've used Photoshop for years but have never had this happen. My tools are all coming up as a
rather than the brush (a paint brush), or crop tool for example. How do I change them back so that the picture is what the tool is?
I'm damned if I can work it out!
Hope that makes sense
All help much appreciated.
Sarah
Old 09-07-2009, 7:11 PM   #2
tomson's Avatar
7,527, Level: 20
Points: 7,527, Level: 20 Points: 7,527, Level: 20 Points: 7,527, Level: 20
Thanks: Gave 88, Got 189
Re: CS3 Tools problem
Do you mean your cursor is showing as a '+'? If so, you have Caps Lock on.
squizza (10-07-2009)
