£100 to spend
Old 30-06-2009, 2:47 PM   #1
petrolhead's Avatar
16,316, Level: 30
Points: 16,316, Level: 30 Points: 16,316, Level: 30 Points: 16,316, Level: 30
Thanks: Gave 97, Got 54
£100 to spend
My company has asked me to get a compact digital camera.
Are there any sites that you can search for camera with specific features and price range?
Failing that I was hoping to get some or all the following features but quite understand that at £100 my choice is limited
Please don't suggest cameras that are over £120 as my company is a charity will not go much over budget
This is what would be nice:
3x Optical
28mm wide
Image Stabilisation
Good macro
easy to use
Old 30-06-2009, 2:59 PM   #2
Paranormalist's Avatar
10,827, Level: 24
Points: 10,827, Level: 24 Points: 10,827, Level: 24 Points: 10,827, Level: 24
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
Thanks: Gave 1,339, Got 622
Re: £100 to spend
Camera Price Buster - UKs cheapest camera gear
Old 30-06-2009, 3:04 PM   #3
Jammyb's Avatar
8,297, Level: 21
Points: 8,297, Level: 21 Points: 8,297, Level: 21 Points: 8,297, Level: 21
Activity: 26.9%
Activity: 26.9% Activity: 26.9% Activity: 26.9%
Thanks: Gave 47, Got 321
Re: £100 to spend
Canon PowerShot A590 IS £93.72 inc VAT & Shipping at Dell?
Old 30-06-2009, 3:11 PM   #4
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
Re: £100 to spend
PriceRunner United Kingdom - Compare Prices and Find Best Deals Online will let you do this, but it's easier to just browse through the compacts on CPB... which turned up this: Panasonic DMCLZ10 Digital Camera - Silver 2.5" LCD: Amazon.co.uk: Electronics & Photo
HTH.
Old 30-06-2009, 4:12 PM   #5
OrbitalPete's Avatar
4,032, Level: 14
Points: 4,032, Level: 14 Points: 4,032, Level: 14 Points: 4,032, Level: 14
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 112, Got 321
Re: £100 to spend
For electronics Dabs is always worth a look - especially if you're looking for sub-category/feature selection dabs.com - Laptops, Components, MP3 players, Software, Digital Cameras
Old 01-07-2009, 1:23 PM   #6
petrolhead's Avatar
16,316, Level: 30
Re: £100 to spend
It's not wide angle
HTH.
Brilliant, thats the one I am buying
