Which external flash for NIKON D40 ?
Old 12-06-2009, 2:10 PM   #1
2,628, Level: 11
Points: 2,628, Level: 11 Points: 2,628, Level: 11 Points: 2,628, Level: 11
Question Which external flash for NIKON D40 ?
I know the NIKON D40 camera comes with a built in flash but I need something that little bit bigger with a stronger flash
As part of my job I occasionally take photographs of the inside of newly refurbished buildings ie before and after shots (I know - not very exciting)
I have used my own NIKON D40 camera for this but have found the flash not strong enough for very large rooms (accommodating 70 - 80 staff)
Any advice on which external flash to get (£100 max)
Old 12-06-2009, 2:30 PM   #2
Pirate!!'s Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 523, Got 1,253
Re: Which external flash for NIKON D40 ?
Cullmann 34 AF-N Flash for Nikon
Nikon Speedlight SB-400 External Flash: Amazon.co.uk: Electronics & Photo
A candle or torch.
I know diddly squat about your system BTW.
Old 12-06-2009, 3:13 PM   #3
7,333, Level: 20
Points: 7,333, Level: 20 Points: 7,333, Level: 20 Points: 7,333, Level: 20
Thanks: Gave 10, Got 16
Am not familiar with 3rd party but sb400 seems the best bet, although the sb600 is far better but double your budget.
Old 12-06-2009, 6:23 PM   #4
2,628, Level: 11
Re: Which external flash for NIKON D40 ? mind now made up
Thanks guys - thats made my mind up - its the Nikon Speedlight SB-400 External Flash for me
Old 12-06-2009, 10:53 PM   #5
Boldonion's Avatar
1,937, Level: 10
Points: 1,937, Level: 10 Points: 1,937, Level: 10 Points: 1,937, Level: 10
Thanks: Gave 4, Got 44
Hope it's not too late, go for a Nissin Di 622. Does most things the SB-600 can do and is under a hundred notes. Better value than the sb-400 totally.
