D60 battery - Original or aftermarket?
Old 28-05-2009, 5:17 PM   #1
1,981, Level: 10
Points: 1,981, Level: 10 Points: 1,981, Level: 10 Points: 1,981, Level: 10
Thanks: Gave 0, Got 2
Looking for a spare battery for Nikon D60, the orginal battery is around £39.99. Is it worth considering an aftermarket type, or should I stick to orginal kit? Does anyone have any experiances of aftermarket batterys?
Old 28-05-2009, 5:37 PM   #2
2,738, Level: 12
Points: 2,738, Level: 12 Points: 2,738, Level: 12 Points: 2,738, Level: 12
Thanks: Gave 12, Got 32
Re: D60 battery - Original or aftermarket?
The manufacturer will tell you about the horror stories of a leaking battery wrecking your camera and they would be correct. However, I have bought a few aftermarket types for a few of my cameras and they have been fine. I would admit that one of them died after a couple of years of little use but this can happen to any battery. My only recommendation is that you don't leave a battery in an unused camera for any length of time as this will increase the risk of leakage. I use the camera and then take the battery out before tucking it away. I think I bought a pack of two for my canon camera and they cost me about £10 or so. Good value as far as I am concerned.
Old 28-05-2009, 6:53 PM   #3
1,981, Level: 10
Originally Posted by Bobdk View Post
Good advice, thank you. There are some D60 aftermarket batterys for sale on this site for very little money. Assume i'll be ok if I remove them after using the camera.
Cheers,
Glyn
