Not sure just what you mean but if you mean you get blur on Zoom
It could mean : the lens is faulty
or
You are using the IS at its limits
The long end of a Zoom does magnify hand shake and this is one instance when IS proves itself unless you are asking too much of it
If you use the lens handheld at a very low shutter speed IS will not work
A little more info on what shutter speed , focal length and shooting conditions and aperture) the IS is failing would be helpful
The use of Flash Higher and higher ISO can limit your reliance on IS
and there is always the tripod..
