29-04-2009, 8:39 AM
#1 (permalink)
| | Member
Thanks: Gave 20, Got 63 | Basic Lens for 400D
I'm looking for a lens for my 400D which is suitable for carrying around all day instead of my rather bulky & heavy Sigma 18-200 zoom.
I love my Sigma, and it's fine most of the time, but, for example, I'm planning to spend all day today walking round London, and am going to find it a bit cumbersome.
What I'm looking for is the lightest and smallest standard lens of at least reasonable quality, preferably sub-£100.
The one I've got my eye on is the Canon EF 50mm f1.8 II, which Amazon have for about £80.
Any comment gratefully received.
Many thanks
29-04-2009, 8:45 AM
#2 (permalink)
| | Member
Thanks: Gave 19, Got 26 | Re: Basic Lens for 400D
the canon 50mm is what I would go for if your looking for a small lens for under £100. Or if you wanted to save money you could go for the canon standard kit lens 18-55, but I would stick to the 50mm  .
__________________ 42" PHILIPS 1080P TV | XBOX 360 | PS3 | Humax HD | DENON 3806 | KEF IQ5 / KEF IQ2C / WHARFEDALE 9.1 | iMac C2D | Macbook C2D
CANON DSLR 5D mkii | Canon DSLR 40D | 20mm | 50mm | 105mm macro | 430 EX My Crib |
29-04-2009, 8:56 AM
#3 (permalink)
| | Member
Thanks: Gave 151, Got 123 | Re: Basic Lens for 400D
__________________ Kit: Canon 50D,Canon 400D,Canon Grips,Canon EF-S 10-22mm f/3.5-4.5,Canon EF 50mm f/1.8,Canon EF 100mm f/2.8, Canon EF 70-200mm f/4 L IS,Canon EF 100-400mm f/4.5L IS USM,Canon Extender EF 2x II,Canon 580EX,Canon HD HF10, Manfrotto O55PROB tripod and 3-way head 804RC2. MY PHOTOS ON FLICKR |
29-04-2009, 9:01 AM
#4 (permalink)
| | Moderator
Thanks: Gave 425, Got 2,080 | Re: Basic Lens for 400D
The 50mm is light and sharp but for every day walk about use, I would suggest you limit yourself to 50mm on the 18- 200 and see if you can live withthat focal length fixed
If not you will find it limiting and may need to get the Kit 18-55 IS
__________________ S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine! |
29-04-2009, 9:45 AM
#5 (permalink)
| | Senior Member
Thanks: Gave 35, Got 535 | Re: Basic Lens for 400D
I've tried to use a 50mm f1.8 as a walkaround. It would be pretty bad for shooting in a city I reckon.
I'd second a 18-55IS on a budget.
If you want a prime, I'd say something around 28-35mm would be good for street shooting, but not so hot for buildings.
30-04-2009, 11:06 AM
#6 (permalink)
| | Member
Thanks: Gave 20, Got 63 | Re: Basic Lens for 400D
Thanks, guys.
I'd ruled out any type of zoom/IS lens on the grounds of probable weight, but the 18-55IS is only 200gm, compared with 130gm of the 50mm, and over 600 for my Sigma, so it's a definite possible.
I'll give 'em both a try.
Had a good day out yesterday, but I did find lugging the Sigma around for 5 hours a bit of a trial.
