24-02-2009, 11:48 PM
#1 (permalink)
| | Member
Thanks: Gave 78, Got 67 | Options other than a 10-20 Sigma
As stated, what other options are there Nikon mount?
I've played with the 10-20 Sigma and must admit it fell short of my expectations.
Looking for something along the lines of 15+ for landscapes.
24-02-2009, 11:57 PM
#2 (permalink)
| | Senior Member
Join Date: Mar 2001 Location: Christchurch , New Zealand
Thanks: Gave 51, Got 224 | Re: Options other than a 10-20 Sigma
15+ what, focal length?
How did the 10-20 fall short of your expectations?
(BTW I love mine and its mostly stuck at 10mm).
Options are the sigma 12-24, tamron 11-16, tokina 10-24, nikon 14-24f2.8 etc.
25-02-2009, 10:42 AM
#3 (permalink)
| | Veteran Member
Thanks: Gave 616, Got 895 | Re: Options other than a 10-20 Sigma
I had the sigma 10-20 and couldn't get on with it just seemed very soft when you started getting to smaller apertures like F16 but could just be me, I've seen plenty good shots taken with this lens. Recently bought a 2nd hand Nikkor 12-24 and really like it I think the tamron 17-50 2.8 will struggle to get a look in from now on I find it that good. Seems the new Tokina 11-16 2.8 is the pick of the bunch from what I've read regarding the UWA.
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
25-02-2009, 3:38 PM
#4 (permalink)
| | Member
Thanks: Gave 189, Got 132 | Re: Options other than a 10-20 Sigma Quote:
Originally Posted by dazza74 I had the sigma 10-20 and couldn't get on with it just seemed very soft when you started getting to smaller apertures like F16 but could just be me, I've seen plenty good shots taken with this lens. Recently bought a 2nd hand Nikkor 12-24 and really like it I think the tamron 17-50 2.8 will struggle to get a look in from now on I find it that good. Seems the new Tokina 11-16 2.8 is the pick of the bunch from what I've read regarding the UWA. | Sorry for going off topic, how much better would you rate the Tamron 17-50mm over the Nikon 18-55mm kit lens?
I am assuming that you have used the kit lens.
25-02-2009, 4:25 PM
#5 (permalink)
| | Prominent Member
Thanks: Gave 926, Got 472 | Re: Options other than a 10-20 Sigma
I'm wondering just how much more than 15 you actually want, and do you really need a fast lens for landscape?
25-02-2009, 5:11 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 211, Got 328 | Re: Options other than a 10-20 Sigma
I've a friend (with a D300) that has switched from the Sigma 10-20 to the new Tokina 11-16 2.8 and says the IQ is much better.
I think the only problem with the Tokia seemed to be getting hold of a copy (not sure if it's still the same now, but they were in short supply)
25-02-2009, 5:15 PM
#7 (permalink)
| | Member
Thanks: Gave 78, Got 67 | Re: Options other than a 10-20 Sigma
I may have been tipsy when i posted started this thread
Can i use my P type filters on a Sigma 10-20 or will you 'see' the holder?
Whats putting me off, nothing that i can point a finger at and say 'That' , but something just doesnt sit right, maybe it was the type of shot I was trying or the location [didnt really lend itself to ultra wide]
These price rises are getting daft now. I have the money for the Nikon 12-24, but now its just getting crazy.
25-02-2009, 5:26 PM
#8 (permalink)
| | Member
Thanks: Gave 55, Got 37 | Re: Options other than a 10-20 Sigma Quote:
Originally Posted by Farno I may have been tipsy when i posted started this thread
These price rises are getting daft now. I have the money for the Nikon 12-24, but now its just getting crazy. | Sounds like the problem might be with the composition of the images rather than the lens? The Sigma 10-20 is very well thought of, I'd love one myself (finances sadly don't allow it) |
25-02-2009, 5:31 PM
#9 (permalink)
| | Prominent Member
You can get a special wide angle holder for it and will only see a tad of vignetting at the widest (10mm).
02-03-2009, 12:14 AM
#10 (permalink)
| | Senior Member
Thanks: Gave 51, Got 224 | Re: Options other than a 10-20 Sigma Quote:
Originally Posted by dazza74 I had the sigma 10-20 and couldn't get on with it just seemed very soft when you started getting to smaller apertures like F16 but could just be me, I've seen plenty good shots taken with this lens. Recently bought a 2nd hand Nikkor 12-24 and really like it I think the tamron 17-50 2.8 will struggle to get a look in from now on I find it that good. Seems the new Tokina 11-16 2.8 is the pick of the bunch from what I've read regarding the UWA. | Uh you do realise that diffraction will kick in at f10-11 or so making any image with any lens soft at smaller apertures?
And that at f8 you get a HUGE depth of field if you use hyperfocal distance etc there realy isnt much need (apart from slow shutter speeds) to go above f10.
I use cokin P (normal holder) with my 10-20 it can be an issue below 12mm sometimes.
02-03-2009, 11:18 AM
#11 (permalink)
| | Veteran Member
Thanks: Gave 616, Got 895 | Re: Options other than a 10-20 Sigma Quote:
Originally Posted by RobDickinson Uh you do realise that diffraction will kick in at f10-11 or so making any image with any lens soft at smaller apertures?
I use cokin P (normal holder) with my 10-20 it can be an issue below 12mm sometimes. | It's people like you that remind me why I spend less and less time on this section of the forum.
02-03-2009, 11:26 AM
#12 (permalink)
| | Veteran Member
Originally Posted by mij Sorry for going off topic, how much better would you rate the Tamron 17-50mm over the Nikon 18-55mm kit lens?
Thanks | Never had the 18-55, I started with the kit lens for the D80 which was the 18-70mm DX. How much better I don't know I think we all suffer with some form of placebo effect when dropping good money on any new lens. Great versatility the 17-50 2.8 for me you can use it as a portrait lens due to being 2.8 and makes a lot of sense I feel given the relatively high costs of faster primes, not bad on the landscape front either. Nice replacement for a kit lens I feel money well spent.
02-03-2009, 12:47 PM
#13 (permalink)
| | Prominent Member
Thanks: Gave 330, Got 1,160 | Re: Options other than a 10-20 Sigma Quote:
Originally Posted by dazza74 It's people like you that remind me why I spend less and less time on this section of the forum. | That's a bit harsh. I thought his explanation to the issues you've been having were both accurate and fair.
Maybe it was just the the use of the word 'Uh'?
Back OT - I have the Tokina 12-24 f/4 which I've been very pleased with. Great build quality, and apart from the chromatic aberration issues in areas of high contrast, the image quality is excellent.
02-03-2009, 7:35 PM
#14 (permalink)
| | Veteran Member
Originally Posted by Liquid101 That's a bit harsh. I thought his explanation to the issues you've been having were both accurate and fair.
Maybe it was just the the use of the word 'Uh'? | I felt it was a bit patronising as a post to be honest and still do, pretty sure if you'd made a similar comment you wouldn't have received that reply.
02-03-2009, 10:05 PM
#15 (permalink)
| | Member
Thanks: Gave 7, Got 59 | Re: Options other than a 10-20 Sigma
Im not happy, placed an order for a 10-20mm Sigma from Cameraworld. They emailed today
basically "Sorry no stock for Sony, when we have them they will be at new stock prices". Charming.
They have updated Sony prices today Sony Fit Sigma 10-20mm
Note the Sale price is £399.99 but it was apparently before the sale £313!!
