24-02-2009, 7:04 AM
#1 (permalink)
Thanks: Gave 373, Got 733
Tamron 55-200mm Di-II LD Macro (Low Prices)
Ahoy!
Anyone still looking to buy something like this ought to look here. Bargain of the moment I think @ £54.99 (Sony/Minolta owners ought to get in quick as the price is the lowest I've ever seen it), though you can still get the non-motorised Nikon mount cheaper here @ £34.99, though it's not compatible with D40, D40x and D60.
I've found the Canon variant here for £79.00 unless you can source it cheaper.
It is an exceptionally decent lens that gives far better IQ than the price tag suggests, so punches well above it's weight. Check out reviews.
24-02-2009, 9:07 AM
#2 (permalink)
Thanks: Gave 13, Got 3
Re: Tamron 55-200mm Di-II LD Macro (Low Prices)
can i still use it on my d40, but it just wont autofocus, or is it totally incompatible?
seems a nice cheap lens , i can put up with manual focus at that price.
24-02-2009, 11:03 AM
#3 (permalink)
Thanks: Gave 2, Got 5
Thanks pirate just bought one for my Sony A200, still using the kit lens at the moment so this will be a good extra to have.
24-02-2009, 1:08 PM
#4 (permalink)
Thanks: Gave 1, Got 11
how does it compare to the Sigma 70-300mm f/4-5.6 APO Macro DG??? are the for the same use`s???? just with a little less reach????
24-02-2009, 2:32 PM
#6 (permalink)
Thanks: Gave 2, Got 0
Many thanks Pirate
Cheapest Sony mount one i've seen for ages.
Just ordered one for my A300.
24-02-2009, 4:45 PM
#7 (permalink)
Data provided is from retailers websites. I would suggest you contact them or ask the Nikon fraternity as I don't know your system well enough to give a qualified reply.
24-02-2009, 4:46 PM
#8 (permalink)
No problem. Buy 2 and do as you will with the other!
24-02-2009, 4:53 PM
#9 (permalink)
Originally Posted by mcstone
Many thanks Pirate
Way to go
24-02-2009, 5:00 PM
#10 (permalink)
Originally Posted by mrpink123
Ahoy!
And the overlap from 55mm wide end on the Tammy and 70mm long end on the SAL means you're extending the range of the SAL from 17mm (it's creaking @ 70mm and IQ wouldn't be great fully extended anyway), so not a bad combo if you can live with the shortcomings of the kit lens. The Sigma 70-300 is actually a decent budget telezoom and the 1:2 macro is excellent, but you have to use it fully extended @ 300mm which is a bit hit and miss, though none-the-less, can get nice detailed close-up's if you have steady hands.
Horses for courses, but in the current financial climate, the Tammy is hard to ignore at the advertised price (the average is £110.00 +). Certainly less £'s than I paid for mine, so why not bag a bargain whilst they can still be found?
24-02-2009, 5:54 PM
#11 (permalink)
Thanks: Gave 55, Got 37
Horses for courses, but in the current financial climate, the Tammy is hard to ignore at the advertised price (the average is £110.00 or more). Certainly less £'s than I paid for mine  so why not bag a bargain whilst they can still be found?
Definitely agree with this. I have the Sigma and love it, but if I didn't I would be picking one of these up.
25-02-2009, 9:38 AM
#12 (permalink)
Got my lens already, excellent service from collegecameras. Great buy for the price
25-02-2009, 12:19 PM
#13 (permalink)
Same here, only ordered it yessterday morning.
A dinky little thing it is too.
25-02-2009, 5:33 PM
#14 (permalink)
Ahoy!
That sounds like excellent service and price to boot. Hope you and pcfarrar find it as useful and as easy to use as I and others do. It's a cracking little lens.
Oh well, let's see what other bargains are out there  Hopefully if anyone spots anything, they'll post their findings too.
25-02-2009, 6:37 PM
#15 (permalink)
any chance of a pic of it stuck on your camera???
