Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 24th at 9:30pm and include delivery.
Jamo A102 vs Tannoy SFX5.1 vs Canton Movie 60CX biggy7 Speakers 20 09-02-2009 10:55 AM
Full HD 32 or 37", LCD Vs plasma, Panasonic 32lzd80/85, Sony w4000, Samsung LE32a558 davross81 Which LCD TV Should I Buy? 18 14-01-2009 4:00 PM
Looking to buy Nikon D90 DaveM Digital Photography General Chat 7 14-01-2009 8:39 AM
Sony HTSF1300 vs Sony HTIS100 T0adL0ader All-in-one Systems 4 13-01-2009 4:29 PM
Old 13-01-2009, 10:12 AM   #1 (permalink)
Thanks: Gave 1, Got 0
Nikon 55-200mm f/4-5.6 AFS G VS Sigma 70-300mm f/4-5.6 APO Macro DG
I am very new to the world of DSLR. I purchased a D50 from stock left over within our business and it came with the standard 18-55mm lens. I feel I need a further lens so that I can enhance my photography, through macro and zooming.
Having looked, I feel I have two choices, which won't break the bank. The Nikon 55-200mm f/4-5.6 AFS G or the Sigma 70-300mm f/4-5.6 APO Macro DG.
I don't know much about lens' at all and I'm looking to this forum to give me some laymens terms on both of these Len's and tell me which would be the better by.
I like the option to zoom in on things and also the option to take close up photos - but which is the best for my needs.
Your responses would be much appreciated..!!
3canaries is offline   Reply With Quote
Old 13-01-2009, 11:04 AM   #2 (permalink)
Thanks: Gave 168, Got 153
Re: Nikon 55-200mm f/4-5.6 AFS G VS Sigma 70-300mm f/4-5.6 APO Macro DG
I've owned both, the Nikon was my first purchase to compliment my 18-55mm kit lens but I soon changed it for the Sigma and found that I didn't miss that 55-70mm range at all.
Both lens will (obviously) allow you to zoom in, the Sigma a little more than the Nikon...but it's the macro capability of the Sigma which makes it the winner for me. It has a dedicated switch which allows you to shoot 1:2 macro images (true macro lenses are 1:1) when using the 200-300mm focal lengths. The setting also allows you to get physically closer to your subject - you can be as close as 95cm instead of 150cm during normal use.
Does the D50 have a built-in autofocus motor? If so, the APO Sigma lens you'd need (without it's own internal motor) is only £119, as opposed to £159 with built-in autofocus motor.
Hope that helps.
julian
My Flickr | Nikon D700 | Nikkor AF-S 24-70mm f/2.8G ED | Nikkor AF 50mm f/1.8D | Sigma 70-300mm APO DG Macro f/4-5.6 | Nikon SB-600
julian_fraser is offline   Reply With Quote
Old 13-01-2009, 11:21 AM   #3 (permalink)
Thanks: Gave 617, Got 895
In hindsight 1/30 second shutter speed is maybe a bit to slow but might help a little bit. I've taken these on my 70-300mm VR (if you can find another £150 I would get this over the other two mentioned personally but appreciate it's a lot more money to find)
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
dazza74 is offline   Reply With Quote
Old 13-01-2009, 8:07 PM   #4 (permalink)
Thanks: Gave 4, Got 8
Hello,
I own a D50 and unlike the newer D40/60 it has its own motor so wider choice of lenses.
DaveM is offline   Reply With Quote
Old 13-01-2009, 8:33 PM   #5 (permalink)
Thanks: Gave 39, Got 199
I was thinking about the Sima 70-300MM as I need Zoom and macro, but I didn't like the look of the lens, and no VR or Autofocus...
meansizzler is offline   Reply With Quote
Old 13-01-2009, 8:37 PM   #6 (permalink)
jomike's Avatar
Thanks: Gave 309, Got 316
I got a Sigma 70-300 APO when I got my D50 just over two years ago, and I would recommend it. As dazza74 says, the Nikon 70-300VR has VR which is nice to have when shooting in low light at 300mm, and the image quality is slightly better at 300mm. However it is quite a lot more expensive than the Sigma 70-300 APO, and also I don't think you will get shots like this one taken with the D50 and the Sigma 70-300 APO in 1:2 close up mode. (Nikon 70-300 VR does not have a close up mode) That is if you like this kind of thing, of course
Mike
My flickr
jomike is offline   Reply With Quote
Old 13-01-2009, 8:40 PM   #7 (permalink)
jomike's Avatar
The OP has a D50, so all Sigma 70-300 versions will autofocus on his camera, no VR though as you say.
Mike
My flickr
Old 13-01-2009, 8:57 PM   #8 (permalink)
Thanks: Gave 333, Got 161
Beautiful
Originally Posted by jomike View Post
Ned Senior is offline   Reply With Quote
Old 13-01-2009, 8:59 PM   #9 (permalink)
Hope that helps.
To anyone else reading this thread looking at the Sigma Lens there is infact a £150 one that does NOT have the autofocus function for D40/D60
I nearly made the mistake of buying one today.. lucky we tested it in the shop!
Old 13-01-2009, 10:12 PM   #10 (permalink)
Boldonion's Avatar
Thanks: Gave 4, Got 36
Heads up.....There is a mint Nikon mount APO DG 70-300mm with built in motor available in the for sale section for £115 .
Resistance is futile
Boldonion is online now   Reply With Quote
Ned Senior (14-01-2009)
Old 14-01-2009, 12:07 AM   #11 (permalink)
Great but am gonna try and get a nikon vr jobbie before they all go up to £365 as they have at my local store
I prefer new anyway with hi tech items.
dvds books etc are fine used tho'
afs, apo, f or, macro, nikon, sigma
