Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 22nd at 5:30pm and include delivery.
Left tripod in field, bought new tripod, took a photograph Tobers Digital Photography General Chat 13 24-05-2008 9:03 AM
New flashgun new tripod & foul weather Luffy Digital Photography General Chat 0 03-01-2008 9:14 PM
I need a new tripod chris1210 Digital Photography General Chat 1 07-11-2006 8:41 PM
Looking For A New Tripod (£100 budget) Advice Needed! iGiDK Digital Photography General Chat 9 15-10-2006 7:44 AM
Time drags (new Tripod waiting at home) Nick Cartwright Digital Photography General Chat 6 18-07-2006 1:40 PM
Old 16-12-2008, 12:33 PM   #1 (permalink)
Paranormalist's Avatar
Thanks: Gave 637, Got 478
Question New Tripod Instructionnaire
Bought this tripod and head from Redsnapper. Had it delivered today. More levers and screws than two hands could handle! Anyone got an idea how to use it and get a camera on it too? A tutorial would be good.
Thanx
Para
Flickr
Pentax K20D l 16-45mm l Sigma 70-300mm APO l Pentax-A 50mm f/2 l Samsung SEF-36PZF flash
Paranormalist is offline   Reply With Quote
Old 16-12-2008, 1:03 PM   #2 (permalink)
Thanks: Gave 61, Got 97
Re: New Tripod Instructionnaire
Well to start with I'd remove the camera plate from the tripod and attach it to the camera.
Then to move the head position all you need to do is rotate the handle to slacken it, move the head to the desired position and re-tighten.
Adjusting the leg lengths should be the same principle.
It's not rocket surgery
Marque.Zenfolio.com
Some Bloke is offline   Reply With Quote
Old 16-12-2008, 1:09 PM   #3 (permalink)
Mike.P®'s Avatar
Thanks: Gave 242, Got 315
Yikes, thats a good price, pity they are not doing it with the ball head but I really cannot refuse at that.
Am just about to leave for flight back to Spain but will order that when I get back.
Cheers.
My Flickr
My Pentax Gallery
Mike.P® is online now   Reply With Quote
Old 16-12-2008, 2:08 PM   #4 (permalink)
Yeah it's more like rocket science!
Flickr
Old 16-12-2008, 2:32 PM   #5 (permalink)
Thanks: Gave 50, Got 166
When you do work it out, let us know what you think of it. I was considering one of these as a Christmas present to myself.
regards
Brian
bsuttie is online now   Reply With Quote
Old 16-12-2008, 2:37 PM   #6 (permalink)
regards
Brian
Hopefully I'll be able to tell ya by Xmas 09!
First impressions are very good. Very solid/sturdy compared to my manfrotto. Now just to figure out how to remove the camera plate...
Flickr
Old 16-12-2008, 6:06 PM   #7 (permalink)
Pirate!!'s Avatar
Thanks: Gave 373, Got 732
Ahoy!
The tripod and ballhead are excellent. Remove the plate from the head (unscrew locking screw and press silver release pin on side), turn over and you'll see a securing screw with a flip-up lever in the centre of the upturned plate. Screw this to your camera body. Then slide body/plate/lens onto the head and press the retaining button on the side of the ballhead and slide into central position. Once there, tighten the locking screw thread to secure plate to ballhead.
Then it's a matter of adjusting to suit yourself in terms of shooting you want to do (they are very senstive to adjustment). Make sure if you're on even ground to screw-out the tripod rubber feet, or if on soil, screw-in to reveal the tripod foot spikes.
It's an extremely sturdy and robust tripod and head. It won't take much to work it out (only a few adjusters), and the height is simply a twist on the rubber grips (there are two for each leg) for full height or intermediate.
I had the full set-up on mine over the weekend and it stood very firm.
EDIT: I see you went for pan/tilt head, in which case the above probably doesn't apply in your case. I went for this and this.
Pirate!
First, I'll rob you blind, then negotiate a discount! flickr Jetphotos My Gear
Pirate!! is offline   Reply With Quote
Old 16-12-2008, 6:18 PM   #8 (permalink)
Thanks for taking the time, Pirate. I think I may have worked it out... eventually! Here's a first pic from new tripod.
Flickr
Old 17-12-2008, 3:23 PM   #9 (permalink)
Thanks: Gave 74, Got 326
I've had one of these for a month or so now. Only really used it fully once but i do love it and its great value for money.
when i got mine (and this is my first tripod) i emailed them about the lack of instructions and this is what they sent back. Its all pretty easy to figure out but it was good of thme to reply so quickly.
"The parts in the ball head bag are for converting the thread size to fit different tripods. The QR plate on top of the head slides out when the silver button is depressed - it then screws to the bottom of your camera or lens mount ring.
The small knob adjusts the panning movement. The middle size knob needs to be adjusted for the movement 'damping' you prefer when adjusting your camera angle and the large knob is for locking / unlocking the position.
The tripod legs adjust in angle by pulling out the rectangular 'clips' at the top of the legs and moving the leg fully - it then ratchets into three positions on the way back.
If you need to lock the head in place there are three small grub screws under the plastic mounting disc that can be pinched up.
There is a short centre column in the inside pocket of the tripod bag. The parts on each end of the column just unscrew.
EDIT: Actually i have the same set up as pirate rather than the pan and tilt head.
also you get 10% off if your a member of the Talkphotography forums
Dave
Gallery@ http://davepearce.smugmug.com | My S90 images @ flickr
Videos@ http://www.vimeo.com/davepearce/videos
dave_bass5 is offline   Reply With Quote
instructionnaire, tripod
