15-12-2008, 7:38 PM
#1 (permalink)
Thanks: Gave 7, Got 4
Any Sony A300 users here?
Went to Jessops to purchase the A200 (well if they price matched with Amazon, which they don't) and as it turns out they are out of stock until after Xmas. No probs I can always buy from Amazon.
Anyway while I was there I had a play with the A300 which has the Liveview system. It is only £50 more so now I amt hinking about that model. The viewfinder does seem quite a bit smaller so I was after some opinions of anyone who has one about how they have got one with the camera. The only other camera I am looking at is the Nikon D60.
15-12-2008, 8:13 PM
#2 (permalink)
Thanks: Gave 7, Got 15
Re: Any Sony A300 users here?
With fantastic live view and Built in Image Stabilisation on the body I went for A300 over D60/Canon 1000/pentax 200d and have not regretted it...
The kit lens on Sony is 18-70 vis a vis 18-54 for others..
of course Nikon lenses are more widely available but the IS is on the lens
cheers
ajex
16-12-2008, 3:26 PM
#3 (permalink)
Thanks: Gave 50, Got 167
Yes another A300 lover here. I find the combination of liveview plus the tilting screen great for composing high up / low down shots. Have heard a few negative comments about the size of the optical viewfinder but it hasn't bothered me.
regards
Brian
16-12-2008, 5:08 PM
#4 (permalink)
Thanks: Gave 48, Got 78
My son was using the A100, I bought an A300 body for £219 from Fleabay. I now have the A100 and am buying some lenses for it, he loves the A300 and after comparing it with the A100 he decided to swap with me. I think the auto flash pop up and live view swayed his decision, although he did say the A100 was better built.....
16-12-2008, 8:06 PM
#5 (permalink)
Thanks: Gave 373, Got 736
Ahoy!
Does the A300 have DoF preview? A100 does. I wouldn't get hung up over either of them. The A200/300/350 are not major upgrades to the A100, so A100 would be perfectly fine. OK, not great in low-light, so buy a Minolta 50mm f/1.7. Job done.
As for auto pop-up flash. Put the flash down and get an external F42 Sony version from here. Type in: FPANDP for free courier postage. After £30.00 Sony cashback, £97.22 (nett). It will transform your photography, and it's simplicity itself to use (really).
Ask Santa nicely, the investment will be well worth it.
16-12-2008, 9:40 PM
#6 (permalink)
ooooh...mine should arrive tomorrow and i'm very excited!!!
Can anyone recommend any other types of lens in addition to the 18-70 that you 'must own' if you know what i mean....I'd like this info quite soon as i'm off to Goa on thursday so i might buy myself a lens at the airport or when we stop over in the middle east :-)
16-12-2008, 9:45 PM
#7 (permalink)
Ahoy!
Go to Dyxum.com, lenses section. Type in your parameters. Make a short list. Search EvilBay/Amazon/Dyxum for sale section and AVF classifieds.
If you give a budget, focal range and/or intended use, it would help to give more qualified advice.
16-12-2008, 9:53 PM
#8 (permalink)
well i'm complete newbie so for me i just want pin sharp clarity.....th emain use will be of my kids but when i'm on holiday and stuff i will of course be taking shots of all sorts really....
I dont really have a budget either but obviously i want to keep costs as low as possible I saw a Tamron 55-200mm f4.0-5.6 Di II LD Macro for £60 odd mentioned on another thread - would this support my (somewhat vague!) needs?
ps what does 'f4.0.-5.6' mean?
16-12-2008, 10:02 PM
#9 (permalink)
As said in a Monty Python sketch . . . 'Say no more'. Bang for buck, a very well rated lens.
F4 will be the widest aperture available at 55mm. F/5.6 will be at 200mm (narrowest aperture) on the lens unless you adjust the camera for greater depth of field (DoF), say F/8.
Basically, at 55mm at f/4, you will have a narrower DoF (more light, faster shutter speed). As you close it down, say f/5.6 or above, a slower shutter speed, but a greater DoF (more in focus). F8 is a mean average. A tripod helps, but if shooting hand-held, f/5.6 works fine. You can compensate by adjusting the exposure value (EV), say by -0.3 to increase shutter speed slightly, though it depends on the available light and the widest aperture of the lens fitted at the time. Many look for the Minolta 50mm f/1.7 prime lens. It's a classic, so you can get a fast shutter speed in low-light conditions, though at f/1.7 the DoF will be VERY narrow (not much in focus).
The lower the f number, the less in focus, but higher shutter speed. The higher the f number (5.6 and above for example), more in focus, but slower shutter speed.
It's a compromise. Another way to adjust is to increase the ISO (sensor sensitivity), but the Sony is probably best at ISO 400 or below. There are many variations, but foremost (IMHO) is to have a good lens with as bigger aperture as possible . . . and again, this will depend on your shooting requirements.
16-12-2008, 10:03 PM
#10 (permalink)
16-12-2008, 10:13 PM
#11 (permalink)
Thanks: Gave 211, Got 328
Save my poor fingers typing, it's the aperture range of the lens.....
Aperture - Wikipedia, the free encyclopedia
16-12-2008, 10:23 PM
#12 (permalink)
cool thanks :-)
20-12-2008, 1:36 AM
#13 (permalink)
Thanks: Gave 6, Got 10
just to carry on the question above, and the reply above:
'f4.0.-5.6' is range of aperature on lens, so when adjusting the f numbers on the camera is this DoF?
20-12-2008, 7:09 AM
#14 (permalink)
Thanks: Gave 309, Got 316
Adjusting the Aperture (f numbers) affects the Depth of Field (DoF). See here for a detailed explanation.
20-12-2008, 10:26 PM
#15 (permalink)
picked up mine today with sony 18-200
had initial problems with the flash, hope it's sorted now, as with Auto mode and the pop up light pops up, the light didn't flash. but hope it's ok now.
secondly, i've got a dead pixel on the lcd screen, not sure if this would warrant an exchange? small blue dot, guessing it won't affect pictures, but can see it more when on grey menu
edit:
on Auto, and with a bright room, the flash seems to come on. maybe i will check tomorrow during the day
