Buy Tamron 70-300mm F4-5.6 Di AF Macro 1:2 Lens For Sony £106.69
If you can get it cheaper . . . for £100.00 (ish), I'd be happy with one. None on your list will be stellar performers, more like competent. They are after all budget zoom lenses.
EDIT:
If you have a 'few extra shillings', take a look at
this:
It's in the price range of the SAL 70-300 SSM G, but this is f/2.8 and looks like a quality piece of kit. On a personal note, I would go without and save your pennies for a quality lens than making-do; selling and upgrading isn't worth it. It's cheaper in the long run just to go for the jugular! The
reviews on Dyxum for this lens are exceptional.
