03-12-2008, 10:19 AM
#1 (permalink)
Thanks: Gave 14, Got 60
D90 for Safari/Nature Photography? (Newbie)
If the (Newbie) in the title hasn't already alerted you, I've just stumbled into the world of DSLR photography. I do have a background in embedded design so have an understanding of some of the underlying tech. I'm also used to having to research terms/acronyms/etc so you don't have to dumb down the tech side too much for me (I'm happy to go figure out what I don't understand from your posts). Any articles/guides you can point me to would be greatly appreciated aswell.
Anyway back to my question. I've recently come back from Safari in the Mara and along with my partner have decided its the type of holiday we will be aiming to do in the future (already planning a few more). We had planned to borrow my Aunts camera, however my idiotic cousin didn't drop it off in time, so were stuck with our compact. Thats prompted us to decide its time to join the DSLR brigade. Although the compact performed "ok" initially, low light shots and limited zoom were very frustrating.
I've been reading the posts here and revies on dpreview.com to narrow down my choices. And so far the D90 is standing out. Its within the budget we set aside, although I need advice on starter lenses to be sure of that. The sample pictures i've seen look good to my eye. The ability to record video (I've read the limitations) is appealing as coming from a compact I really don't want to have the added bulk of a camcorder aswell. Both my brother (who will also use the camera) and I have a tendancy to "embrace" new hobbies (especially the tech aspect), which is why I haven't gone for a entry level camera.
So given the requirements, is this a good choice or are there others I should consider?
Any recommendations on glass I shoud consider a must have to begin with?
I'm going to spend the next month trying a few camera's in store. I will be buying next month which should allow me to take advantage of post XMAS sales. While also allowing me time to play/practice/learn before our next trip in July/Aug.
Advice much appreciated.
03-12-2008, 10:32 AM
#2 (permalink)
Thanks: Gave 473, Got 820
Re: D90 for Safari/Nature Photography? (Newbie)
D90 would be a good buy IMO and well worth getting as a kit so you also get the 18-105 VR lens (have a look at JoMike's recent pics for an endorsement of that). For safari you'll need some more zoom I feel so budget to also get the 70-300mm VR lens at least.
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
03-12-2008, 11:06 AM
#3 (permalink)
Thanks: Gave 300, Got 297
As Dazza says, the 18-105VR kit lens that comes with the D90 is a nice lens, sharp and the VR (Vibration Reduction) works well in conjunction with the D90's high ISO (sensitivity to light) capability to get nice sharp photos in low light. It is also a nice range for a walkaround (general purpose) lens.
For safari, you need the longest lens you can afford, 300mm is the minimum I would think, 500mm is better. The Sigma 150-500 OS is a favourite of bird photographers at a reasonable price. All the Nikons at this range are excellent but pricey. Tamron do a 200-500mm but it is not stabilised.
03-12-2008, 11:19 AM
#4 (permalink)
I've just been looking at JoMikes thread, some excellent pics there.
In terms of lenses I assume VR would be a must as setting up a tripod may be difficult unless your prepared to mingle with the lions outside the jeep  . I would also need a AF lens (unless I'm happy to do without AF), because from what I read Nikon don't include a motor in the body.
What kind of aperture range should I look for in the zoom lens? From an initial google f/4.5-5.6G seems to be common on the 70-300mm VR lenses.
Initially pricing seems to be around the ~£300 mark for the 70-300mm, and ~£700 for the kit. Hopefully Jan sales may yield some bargains, but worst case I can live with that.
03-12-2008, 11:34 AM
#5 (permalink)
Some nice shots on your thread mike. I would probably put the Dino/E-Type/Miura SV joint top in my list though  (although my list does change depending on which car I last saw in the flesh).
The Sigma 150-500 OS looks interesting. From what I've read I assume it has VR (?) and should AF with the D90? Pricing appears to be around the ~£600 mark, which makes it tempting when compared to the 70-300mm Nikons. Decision, decisions  . Spend £300 on the 300mm and later spend another £600 on the 500mm. Or cough up even more now......
03-12-2008, 11:53 AM
#6 (permalink)
Thanks: Gave 235, Got 511
Don't worry about AF. This is only an issue with the D40 and D60. The D90's fine.
VR/OS/VC/IS are all the same thing, and whilst it may be beneficial, I would say that specifically for safari, it may not be essential. I would think it likely that the light will be strong enough to keep the shutter speed up, even at full zoom. With the D90, you can always bump the ISO with confidence. I suppose for animals in the shade it could come in handy, it's just if you (others) think you could get away without it, it opens up the options/budget a little. This of course all depends on whether you think you could hold the lens steady enough. A real whopper may be a bit difficult I guess.
Budget for the widest aperture you can afford, but with VR/high ISO then the standard f4-f6.3 range should be fine.
Another option may be to rent a decent lens specifically for the trip. grantsteve had a thread about this a few weeks ago and found somewhere with an excellent range and not a huge amount of cash. Not compared to the cost of the lens outright anyway.
James. Ignore my member status. I'm not old and know very little. I'm just very opinionated and lonely.
Canon 30D, Tamron 17-50 2.8, Canon 28-105 3.5-4.5 USM II, Sigma EX 70-200 2.8 APO DG Macro flickr
03-12-2008, 12:49 PM
#7 (permalink)
Renting may be a good idea. Although as a newbie the advantage of buying is I can use any spare moment to familiarise myself with the quirks of the lens. Other problem is, I may not want to give it back once I've had a chance to play with it, which may end up being very expensive
Not having to worry about AF lenses with the D90 is a plus. I had assumed VR would a be a must shooting with high zoom resting on a jeep. But I guess a wider apeture would also mean the shot would be taken quicker, so theres a trade of there. This sounds like its going to be a fun/frustrating hobby, not to mention expensive
03-12-2008, 12:59 PM
#8 (permalink)
Also should have mentioned the reason I'm concerned about low light ability is two fold. Firstly as Denno suggests you may find many animals in bushes, shelter, etc. Secondly many animals are more active early morning/dusk, the lions are a good example of this.
Also you get some striking vista's when the first rays of the sun creep over the horizon (or last rays at sunset).
03-12-2008, 1:52 PM
#9 (permalink)
Thanks: Gave 131, Got 679
In terms of lenses I assume VR would be a must as setting up a tripod may be difficult unless your prepared to mingle with the lions outside the jeep.
If you do go for a bigger zoom such as the Sigma 150-500 you might want to consider a monopod instead of a tripod. Mainly because the 150-500 is a heavy piece of kit. Also you can use it to fend off the lions
John  Feel free to visit my flickr site and my travel pages at Virtual Tourist
My Kit:Pioneer XDE435>Denon 3910>Sky HD>YamahaRXV795>Mission Surround Speakers>BlackBerry Curve 8320>Fujitsu Lifebook A6030>Pure Evoke 3>iRiver H340>Exlim Z750>Nikon D300 and some decent lenses
03-12-2008, 2:00 PM
#10 (permalink)
Thanks: Gave 34, Got 521
Fortunately, VR (or OS in Sigma speak) does mean you can get away with reasonably low shutter speeds in poor light, as you're only worrying about subject movement, and not a shutter speed to steady the lens.
If you're going on one or two wildlife trips per year and you want even better low light performance, I'd suggest renting. For example, you'd have to use a Nikon 80-400VR for 20 weeks to justify buying over renting...
Nikon AF 80-400mm f 4 5-5 6 D ED VR
Other options would be one of the f2.8 zooms and a x1.4/x1.7 teleconvertor maybe.
03-12-2008, 3:55 PM
#11 (permalink)
That does make sense. Provided I don't like it so much I impulsively buy it  .
I think I'll get the kit initially and possibly one zoom lens, so I can practice in my spare time. Anything else I'll probably rent as you suggest, unless I have a moment of madness
03-12-2008, 3:59 PM
#12 (permalink)
I'm hoping to pop into the shops at the weekend so I can get a hands on feel of the camera and lenses. That should help me understand what I can reasonably manage and help balance the desire for huge zoom lenses
Although you are right, tripds and lenses can come in handy when defending yourself (provided your insured of course)
03-12-2008, 4:32 PM
#13 (permalink)
A D90+18-105VR+70-300VR would be my suggestion as a great value enthusiast kit to get you up and running. Both lenses are light, and pretty much as sharp as money can buy.
You actually won't better the 70-300VR for sharpness, even with the multi-thousand quid lenses - they just get longer, and with wider apertures.
Although I've never been on safari, I'd probably hire the 80-400VR (or 70-200VR + 1.4 tele) and if I was going crazy, a 300mm f2.8VR and 1.7 teleconverter and a grab a cheap second body to avoid changing in the field.
03-12-2008, 8:04 PM
#14 (permalink)
Yandros, thats kind of what I'm leaning towards now. Although am tempted to go for the 150-500mm aswell.
I'm going to try and pop into jessops this weekend and have a play with the camera and lenses. Hopefully they will have everything instore.
Do they allow you to play with the kit? Thinking about taking a few memory cards along so I can take some shots and look at them at home.
Are they normally ok with this?
03-12-2008, 8:08 PM
#15 (permalink)
I went to my local Jessops (Greenford, Middlesex) and they were happy to let me try lenses on my camera. That is were I tried the 150-500. Given the current problems they are likely to be facing I am sure they will do even more to try and clinch a sale - that may even include knocking a few quid off  .
