Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 24th at 9:30am and include delivery.
Need Sub £500 DSLR(or DSLR Style) as my Camera Died Today Mark Ward Digital Photography General Chat 12 16-01-2007 11:20 AM
Focus for the blind...Or Actualy Measuring Focus Alaric CRT Projectors 5 10-01-2007 9:07 PM
PTAE100e - focus/blur/focus/blur... bertha Projectors 3 06-02-2006 5:08 PM
Why do all DSLR / Compact debates get closed by DSLR owners ? mjw123 Digital Photography General Chat 10 02-06-2005 6:44 PM
Old 29-11-2008, 3:59 AM   #1 (permalink)
Thanks: Gave 39, Got 199
DSLR with advanced Focus?
After Trying manual focuswiht my compct found that I could now take good shots, but having to press 5 buttons to get to the focus menu and adjust it is a pain, I thought DSLR' made it easy, thought you twist the lense to change the focus but was then told that this only changes the zoom...
So what do I need to get only the fly Focus Adjustment?, Thinking of a Nikon D60 but what lense with the focus adjustment, prefer a 200 or 300mm VR lense to.
Also are the cameras not yet advanced enough to be fitted with lasers that you just point at the object your shooting at it will automatically calculate how far the object is and adjust the settings accordingly?, or is this what they call autofocus?, as I personally find that feature crap, when taking up close shots of PCB's it's no good, have to switch to manual
meansizzler is offline   Reply With Quote
Old 29-11-2008, 5:21 AM   #2 (permalink)
Dave's Avatar
Thanks: Gave 973, Got 896
Re: DSLR with advanced Focus?
All DSLR's allow manual focus from turning the erm, manual focus ring on the lens.
The focus on a modern DSLR is also very accurate indeed and you very rarely have to resort to manual focus unless the light is very poor.
If you want to take close ups of PCB's then you'll need a macro lens. You might just about do it with a standard zoom but if you want to get really close then it's macro all the way.
My opinions expressed here are my own and do not represent those of AV Forums.
My Flickr
Dave is offline   Reply With Quote
Old 29-11-2008, 5:54 AM   #3 (permalink)
Thanks: Gave 425, Got 2,079
You've been misinformed, perhaps unwittingly.
You don't twist the lens though . it is the ring on it as the actual lens casing is rigid although its internal elements move
The lenses have 2 rings; one for zoom the other for focus.
Unless they are prime lenses with dont zoom ( because focal length is fixed,) they only have one ring for focus
All however all have very easy manual focus
As it happens DSLRs and compacts tend to AF differently..more on that below
The cameras do have accurate and quick auto focus in general employing Passive or active methods , which use slightly different means ( (infrared or reflection on sensor with distance computed by electronics( or both)to adjust the lens. AF does have limitations and poor contrast, reflections, user error make it not 100%, but c**p it is not . when it works ( which is most of the time,) it is fast and accurate
DSLRs employ the passive method as a rule
To shoot PCBs sounds like a Macro subject: that would be better done with Manual focus and a dedicated macro lens which allow you to get "up close and personal"
It is possible.. but not as easy with Non Macro lenses
The sigma 70- 300 does some sort of macro but I wouldn't use it if I had a lot to too
An example
PS: Sorry If Ive repeated you Dave.. Someone else might find it useful though
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Dave (29-11-2008)
Old 29-11-2008, 12:04 PM   #4 (permalink)
Fozzybear's Avatar
Thanks: Gave 257, Got 248
For photographing a PCB you don't want a 200 or 300mm VR lens, you need a macro lens. Are you looking to take photos of the whole pcb or parts of it? Probably a short macro lens of 50-60mm would work well if you want to do both, otherwise you'd need to move the camera quite a distance from the board.
I've used a Tamron 90mm macro lens to take photos of details of circuit boards, but although the lens is autofocus I often use manual focus, particularly if very close to the board - it's easier to manually focus so you can place the focus where needed if there are 3D elements. For flat board details like this:
AF would work fine. The Tamron has a large focusing ring and manually focusing is easy to do with it, as is autofocusing.
Paul
My Photos on Flickr
Nature-Watcher - a blog on wildlife, photography and walking.
Fozzybear is offline   Reply With Quote
Old 29-11-2008, 10:21 PM   #5 (permalink)
Any Chance of getting a D60 with a Macro Lens then with Live Preview?and senu did you fix that 350D?, I know a place where I can borrow a few lenses....
Old 29-11-2008, 11:19 PM   #6 (permalink)
Fozzybear's Avatar
The D60 doesn't have live view... it has a live viewfinder.
Paul
My Photos on Flickr
Old 30-11-2008, 10:40 AM   #7 (permalink)
I will this month if you can wait.. Nobody seems to need it, so its gathering dust in the study
You can get used to the viewfinder , you know
S3Stuff
advanced, dslr, focus
