Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 23rd at 1:30pm and include delivery.
Poll: Is the future for DSLRs Crop sensor, or Full frame sensor? Triggaaar Digital Photography General Chat 16 19-12-2007 11:18 AM
Buy the New Nikons - D3 (FX sensor)..OR...D300 (DX sensor)??? dealmaker Digital Photography General Chat 9 11-09-2007 7:36 AM
Nikon D100-(Dirty Image Sensor) Old Vet Digital Photography General Chat 1 24-06-2007 9:17 AM
New EOS 400D - dirty sensor (twice!!!) ianll Digital Photography General Chat 16 25-02-2007 6:33 PM
Dirty Sensor - Please Help!!! geofftelforduk Digital Photography General Chat 18 16-10-2006 3:47 PM
Old 13-10-2008, 8:59 PM   #1 (permalink)
pboreham's Avatar
Thanks: Gave 433, Got 157
Dirty Sensor
I've been meaning to post about my sensor for a while - but its been brought to my attention again today ... so HELP!!!
I've tried to clean it myself, but I dont really know what I'm doing. Does anyone know how much a shop would charge to clean it?
You can see what I mean in the first shot of my Flickr - it has one visible black splodge to the top right. There are actually about 3 of those - the rest are smaller, but still visible on the right (wrong?!) image.
If anyone could point me in the right direction - would be appreciated.
Ta!
PSN: - pbb76 PS3 Games: PES09, Rockband2, GH3, Singstar1&2, GRID, MGS4, GTA4, CizRev, MLB08, Burnout, Buzz, Club, GT5p
"Who are Wings? Only the band The Beatles could have been..."
My FLICKR Page
pboreham is offline   Reply With Quote
Old 13-10-2008, 9:30 PM   #2 (permalink)
Thanks: Gave 35, Got 535
Re: Dirty Sensor
Get a rocket blower and follow the manual guidelines for cleaning the sensor. A blower will shift non-sticky dust, but I've not been hugely impressed with the results.
These guys in London will do a while you wait sensor clean for £28+VAT
Repairs
Yandros is offline   Reply With Quote
pboreham (13-10-2008), scotty94 (13-10-2008)
Old 13-10-2008, 9:36 PM   #3 (permalink)
pboreham's Avatar
Re: Dirty Sensor
Bit of a trot to London, but thats interesting all the same - thanks
My FLICKR Page
Old 13-10-2008, 10:17 PM   #4 (permalink)
Thanks: Gave 45, Got 37
Re: Dirty Sensor
Repairs
Cheers for the link, must get mine cleaned pronto!! bit of a trek for me also to the smoke but worth saving in case I can't find someone more local
Carl
Flickr
scotty94 is offline   Reply With Quote
Old 13-10-2008, 10:21 PM   #5 (permalink)
Thanks: Gave 40, Got 87
Re: Dirty Sensor
By all means take it to a shop and pay to get it cleaned. However dust is a fact of life and sooner rather than later your sensor will get dusty again so what are you going to do? Always take it to a shop for cleaning?
Learn how to clean your own sensor, it really isn't difficult or anywhere near as scary as it sounds or as scary as all the 'alleged horror stories' make it out to be. In actual fact it's dead simple and, as long as you follow a few basic and largely common sense rules, it's perfectly safe.
I wrote an article on my site about all the methods I've used Sensor Cleaning but by far the most effective solution was to buy some Eclipse Liquid and a pack of Sensor Swabs.
  1. Take a photo at the smallest aperture (f/22) against a white background and then examine it at 100% to see the dust.
  2. Put the camera into sensor cleaning mode and take the lens off
  3. Put a couple of drops of Eclipse liquid onto the very tip of a Sensor Swab.
  4. Place the Swab at the very edge of your sensor and apply slight pressure - not hard, just a little more than simply resting the swab on the sensor.
  5. Move the swab across the sensor in one direction (don't go back and forth) in one continuous motion whilst applying the same gentle pressure until the swab reaches the opposite edge.
  6. Lift the Swab off the sensor.
  7. Turn the camera off, replace the lens and take another shot. If there are still specs of dust, repeat with a new swab.
Notes:
Do NOT clean the mirror with a swab. In fact don't clean it at all unless you absolutely have to and even then at the very most you should only use a brush and even then don't apply any pressure at all. Better still use a Rocket Blower.
If you do clean the mirror do this BEFORE cleaning the sensor
You SHOULD use a clean swab for every wipe of the sensor. However Swabs are expensive and you often find that 2 or 3 wipes are needed to clean your sensor. You can use the same swab BUT make sure you apply new Eclipse liquid each time as you don't want a dry swab touching the sensor. You should also be aware that if you use the same swab more than once you can transfer dust back onto the sensor so if you've cleaned 3 times and still it's not dust free, use a new swab.
You CAN do it, it really isn't hard.
Good Luck.
My Kit: A camera and some lenses
Peakoverload is offline   Reply With Quote
pboreham (14-10-2008), scotty94 (13-10-2008)
Old 13-10-2008, 11:29 PM   #6 (permalink)
Thanks: Gave 78, Got 67
Re: Dirty Sensor
I had a similar problem, but a rocket blower wouldnt shift it. As there were no local places to hand the camera over for a wet clean i looked into doing it myself.
I bought this starter kit Digi Pads E2 Starter kit Type 1 (E2KITTYPE1) - Warehouse Express
and followed the simple instructions that are supplied.
Worked a treat, the sensor is now clean and i have no spot on my shots.
It didnt find it difficult or scary, as posted above its common sense really.
flickr
Farno is offline   Reply With Quote
Old 14-10-2008, 7:13 AM   #7 (permalink)
pboreham's Avatar
Re: Dirty Sensor
Thanks guys - whats with all the different sensor swabs? I dont want to get the wrong one, so whats the right size for the D40?
I keep seeing swabs for 1.0x, 1.5x etc etc - which one is right for the D40 please?
My FLICKR Page
Old 14-10-2008, 9:04 AM   #8 (permalink)
Re: Dirty Sensor
I believe these should be fine Digi Pads E2 Starter kit Type 1 (E2KITTYPE1) - Warehouse Express
IIRC the D40 has the same size sensor as the D50, D80 etc. This is also a cheaper way of buying a cleaning kit as Digi-Pads are cheaper then Sensor Swabs and just as good and although you only get a small bottle of the E2 cleaning fluid that will last you ages as you only use a few drops at a time and it's a lot cheaper than buying a large bottle.
Old 14-10-2008, 10:37 AM   #9 (permalink)
pboreham's Avatar
Re: Dirty Sensor
Cool, I'll get that then
My FLICKR Page
Old 14-10-2008, 10:53 AM   #10 (permalink)
denno75uk's Avatar
Thanks: Gave 248, Got 531
Re: Dirty Sensor
Just for anyone interested, alternative kit here. Includes a blower, pec pads, eclipse and sensor swabs.
James. Ignore my member status. I'm not old and know very little. I'm just very opinionated and lonely.
Canon 30D, Tamron 17-50 2.8, Canon 28-105 3.5-4.5 USM II, Sigma EX 70-200 2.8 APO DG Macro flickr
denno75uk is offline   Reply With Quote
Old 14-10-2008, 11:37 AM   #11 (permalink)
RandomLee's Avatar
Thanks: Gave 456, Got 303
Re: Dirty Sensor
I think I might in the same boat as pboreham.
I was out (for only the 2nd time I might add) with my new A200 on Saturday and I noticed a few dust specs in the viewfinder.
Then when I got home I could see a black mark in some of my pics but not others (going by memory I think the pics taken with a smaller apeture were worse but I'm not 100% sure without checking).
The annoying thing is I've only had the camera for over a week and the lens has never been off since I 1st attached it. As I said, this was only the 2nd time it's left the house and it's kept in a camera bag the rest of the time so I'm not sure how it could have got in there.
I tried rotating the lens in it's mount to see if the dust specs moved in the VF but they stay still, so I think that rules the lens out?
Does that sound like it is dust on the sensor, the mirror or in the actual VF?
Cheers,
Lee
Flickr
Last.fm
Xbox 360
RandomLee is offline   Reply With Quote
Old 14-10-2008, 12:13 PM   #12 (permalink)
Thanks: Gave 603, Got 377
Re: Dirty Sensor
Pboreham, Colchester Camera Repairs on Severalls do it for a few local shops I have heard, may be worth a try.
I have done it on my D300 with Sensor Swabs, took a few goes but OK now.
Bill
My Flickr]
Biscuit761 is offline   Reply With Quote
Old 14-10-2008, 12:33 PM   #13 (permalink)
dognuts's Avatar
Thanks: Gave 138, Got 18
Re: Dirty Sensor
What kind of camera have you got?
Canon do one free sensor clean under warranty in the first year.
dognuts is offline   Reply With Quote
dirty, sensor
