Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 21st at 9:30pm and include delivery.
Searching for a new plasma to replace my duffer! dominicwellsuk Plasma Televisions 5 11-12-2007 6:26 PM
EF-S 17-55 - Have I got a duffer? ghibbett Digital Photography General Chat 24 21-06-2007 9:03 AM
Sony HC42E - is it this bad or have I got a duffer? Cardiff Irons Camcorders and Video Editing 7 07-02-2006 7:57 PM
Can you help an old duffer? old-Bill CRT Televisions 25 09-08-2004 9:54 PM
Old 13-10-2008, 8:01 PM   #1 (permalink)
Thanks: Gave 1, Got 26
Sigma 10-20 - Is mine a duffer?
Bought a 10-20mm Sigma from Jessops and having taken my first few shots i'm concerned that it's not the ultra sharp beast it's touted to be.
I see there are problems with quality so took a photo of a brick wall at 10mm to try and figure it out. The 1:1 crop is the centre of the frame and it just doesn't seem sharp enough to me. Should I return it?
Pics are clickable
morleymackam is offline   Reply With Quote
Old 13-10-2008, 8:08 PM   #2 (permalink)
johnaalex's Avatar
Thanks: Gave 164, Got 846
Re: Sigma 10-20 - Is mine a duffer?
I do not think this is a good test to see the sharpness of the lens, I would try some other subjects, something with fine detail and at various apertures and focal lenghts - lenses do have sweet spots! Having said that, if you are unhappy with the purchase for whatever reason then the sooner you take it back the better.
John Feel free to visit my flickr site and my travel pages at Virtual Tourist
My Kit:Pioneer XDE435>Denon 3910>Sky HD>YamahaRXV795>Mission Surround Speakers>BlackBerry Curve 8320>Fujitsu Lifebook A6030>Pure Evoke 3>iRiver H340>Exlim Z750>Nikon D300 and some decent lenses
johnaalex is offline   Reply With Quote
Old 13-10-2008, 8:10 PM   #3 (permalink)
Originally Posted by johnaalex View Post
I do not think this is a good test to see the sharpness of the lens, I would try some other subjects, something with fine detail and at various apertures. Having said that, if you are unhappy with the purchase for whatever reason then the sooner you take it back the better.
I presumed the brickwork would be goof for fine detail? I took the same shots with a friend's 30mm prime and it's soooooooo much better. I would expect a bit but not the full amount.
As for taking it back. I really want a wide angle and the £300 for the sigma is as far as I can stretch. If I can get a better copy though I want it!
Old 13-10-2008, 8:14 PM   #4 (permalink)
Thanks: Gave 51, Got 224
What aperture was that? , focused properly? Tripod/shutter speed?
RobDickinson is offline   Reply With Quote
Old 13-10-2008, 8:17 PM   #5 (permalink)
johnaalex's Avatar
And how much did the 30mm prime cost? Also I just looked at this review Sigma 10-20mm f/4-5.6 EX DC Interchangeable Lens Review and they say one of the weaknesses of the lens is "Softish edges in middle of range", but they say it is better wide open.
So take it back and try another copy of the lens while at the store.
Old 13-10-2008, 8:21 PM   #6 (permalink)
Thanks: Gave 40, Got 87
At 1/160th you can obviously rule out camera shake. However you've used an aperture of f/4 and that could possibly be where the problem lies. The Sigma at large apertures isn't particulary sharp with small fine detail (although I'd have to say that I would expect it to me sharper than these images appear). I'm not saying that what you've got is acceptable but it might be worth trying again using f/8 or f/11 just to see if that improves things.
My Kit: A camera and some lenses
Peakoverload is offline   Reply With Quote
Old 13-10-2008, 8:21 PM   #7 (permalink)
This is another centre crop - this time at f9. Still at 10mm though.
I did realise it was going to be a little soft at the edges but like you say it's supposed to be good wide open. I know the 30mm will have been expensive and it is a prime but I would expect the 10-20 to get a little closer. Most of the landscape shots I've seen seem pin sharp.
Old 13-10-2008, 8:26 PM   #8 (permalink)
I dont have any 100% crops online from mine but the center at f8 is dead sharp, it does have softer edges.
Old 13-10-2008, 8:32 PM   #9 (permalink)
Okay, that is just plain out of focus!
Assuming you didn't move and that you did autofocus and that the lenses AF switch was on, then based on all of that the lens is either front or back focusing. Either way, send it back.
Old 13-10-2008, 9:07 PM   #10 (permalink)
Out of focus at f9 / 10mm ?
1st find and print a focus test chart,
2nd use it, tripod , 45degrees af on the center, see its focusing.
3rd tripod a scene with selftimer at f8 and see how it comes out.
Old 13-10-2008, 9:26 PM   #11 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
first shot looks ok if its straight out of camera. A little soft, but its a 100% crop.
take another lens you're happy with and do a comparison.
richard plumb is offline   Reply With Quote
Old 14-10-2008, 8:20 AM   #12 (permalink)
I am erring towards taking it back to be honest. I'll try a test card and a tripod if I can find one online. I can find plenty of references to it - just no card!
Old 14-10-2008, 8:36 AM   #13 (permalink)
Thanks: Gave 616, Got 895
I've taken my best pics with this lens from around 12-14mm. I've recently sold mine to a relative I just prefer the sharpness of my tamron 17-50. I'll probably look at the Nikon 12-24 later down the line if I really need the width.
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
dazza74 is offline   Reply With Quote
1020, duffer, mine, sigma
