13-10-2008, 3:48 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 174, Got 122 | Macro's with Extensions tubes and ring flash
Decided to go in the back yard armed with the nikkor 60mm micro, kenko extension tubes and the marumi macro ring flash. It's amazing just how much closer you can get with the tubes on.
All images converted to jpg from raw, levels tweaked.
1. Seven Legs (no crop)
2. Ant (cropped)
3. Money spider (cropped)
4. My seven legged friend again (no cropping)
__________________ Nikon D300, nikkor 20mm f2.8, nikkor 50mm f1.4, nikkor 12-24 f4, sigma 24-70 f2.8, nikkor 60mm f2.8 micro, nikkor 70-200 f2.8 VR, sb900, MBD10, TC-20EII. MyFlickr |
13-10-2008, 3:53 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 242, Got 315 | Re: Macro's with Extensions tubes and ring flash
Nice clear shots, the lighting and focus are spot on.
I really need to get myself some sort of ringflash.
13-10-2008, 4:05 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 174, Got 122 | Re: Macro's with Extensions tubes and ring flash Quote:
Originally Posted by Mike.P® Nice clear shots, the lighting and focus are spot on.
I really need to get myself some sort of ringflash. | Thanks Mike.P - it's not easy trying to get subjects in focus with the tubes on.
I got the ringflash from 7day shop a few months back for £94.99 incl delivery.
13-10-2008, 4:22 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 309, Got 316 | Re: Macro's with Extensions tubes and ring flash
Some nice sharp shots.
That ring flash seems to give a nice even spread of light, seems good value for the price.
One thing puzzles me a bit, the point of putting ext tubes on is, I thought, to get beyond 1:1 that the lens will do on it's own. These do not look more than 1:1, unless they were really tiny bugs. Is it perhaps that the ring flash gets in the way when getting really close with ext tubes on a 60mm macro, and you cannot get any closer?
13-10-2008, 5:58 PM
#5 (permalink)
| | Senior Member
Nos 1. and 4. (Leiobunum rotundum) are very small, the body of the spider is tiny.
I did expect to get a little closer but with all 3 tubes on you have to almost be touching the subject to get it in focus, not possible with the ring flash on.
13-10-2008, 6:14 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 309, Got 316 | Re: Macro's with Extensions tubes and ring flash Quote:
Originally Posted by imcarm Nos 1. and 4. (Leiobunum rotundum) are very small, the body of the spider is tiny.
I did expect to get a little closer but with all 3 tubes on you have to almost be touching the subject to get it in focus, not possible with the ring flash on. | I thought the working distance might be a problem on a 60mm with tubes. Good excuse for a new longer lens?
I had the same problem when I tried reversing my Nikon 50mm f/1.8 on to my Tamron 90mm macro, I was shading the subject with the lens.
BTW, 1 and 4 are technically a harvestman, an arachnid but different family from the spiders. |
13-10-2008, 10:10 PM
#7 (permalink)
| | Prominent Member
Thanks: Gave 687, Got 666 | Re: Macro's with Extensions tubes and ring flash
4 very nice shots. Like the harvestman ones best. Great results with the kit.
Dave flickr |
14-10-2008, 8:19 AM
#8 (permalink)
| | Senior Member
Join Date: Dec 2004 Location: Devon, Sussex or somewhere inbetween.
Thanks: Gave 342, Got 509 | Re: Macro's with Extensions tubes and ring flash Quote:
Originally Posted by imcarm it's not easy trying to get subjects in focus with the tubes on. | Very true!
Were these hand held or tripod mounted? Nice job either way.
Chris. Serial Procrastinator. EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky |
14-10-2008, 9:19 AM
#9 (permalink)
| | Senior Member
Originally Posted by T0MAT01 Were these hand held or tripod mounted? Nice job either way.  | These were taken hand held mate, but I do need to invest in a longer macro. If only the nikon 2x TC I bought would work with the 60mm micro
