Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 22nd at 8:30am and include delivery.
has my PS3 died? Red Light, Green Light, Yellow Light, Flashing Red Light?!? mattrixdesign2 PS3 24 15-09-2009 9:20 AM
Please recommend a Light tent Pieeater Digital Photography General Chat 2 11-08-2008 11:59 PM
Correct lighting for 80cm Light Tent tigermad Digital Photography General Chat 1 12-02-2008 10:02 AM
xbox light gun please recommend one for 100hz tv mystic_bertie Xbox 4 01-11-2005 5:56 PM
Old 28-09-2008, 7:26 PM   #1 (permalink)
Thanks: Gave 168, Got 153
Recommend a light tent?
Hi all
My wife has a new range of her bunnies coming out soon (no, you didn't read that wrong see here for an explanation!) and wants to photograph them in a light tent for a brochure.
I know it's simple enough to make a DIY one but the table-top fold-away ones are fairly cheap and will be easier to store. I've already got lights that would suffice.
Does anyone use a light tent that they can recommend?
So far I'm leaning towards this from Steve's Photo Shop.
julian
My Flickr | Nikon D700 | Nikkor AF-S 24-70mm f/2.8G ED | Nikkor AF 50mm f/1.8D | Sigma 70-300mm APO DG Macro f/4-5.6 | Nikon SB-600
julian_fraser is offline   Reply With Quote
Old 28-09-2008, 10:05 PM   #2 (permalink)
onefivenine's Avatar
Thanks: Gave 687, Got 666
Re: Recommend a light tent?
I don't have one but have had this on the wish list for a while, and that one looks ideal.
In terms of what its function is, it can hardly be a bad purchase by my reckoning..... it's not like it isn't going to diffuse the light, eh?!
The interchangeable backgrounds look ok.
What can possibly go wrong? And all for the price of a family chinese takeaway - give or take.
I say go for it... in fact I'm about to press the button.
Nice bunnies by the way... could be after one of those for a present.
Dave
flickr
onefivenine is offline   Reply With Quote
julian_fraser (29-09-2008)
Old 28-09-2008, 10:05 PM   #3 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
I think thats either the one I got (80cm) or very very similar (probably all made by the same company anyway). its ok. Usual popup stuff means very difficult to fold away. The 'infinity' backgrounds are a bit rubbish. Veloury which is good to absorb light and avoid reflections, but they're a bit crinkly so they need ironing all the time.
Get as big as you can handle, to get space between the subject and the backdrop.
At the end of the day you could do a similar job with some coat-hangers and some muslin, but this does it for you at a decent price
richard plumb is offline   Reply With Quote
Old 29-09-2008, 8:02 AM   #4 (permalink)
tdodd's Avatar
Thanks: Gave 47, Got 164
I bought an 80cm popup tent, complete with four coloured backdrops, from eBay for about £14 or £15 delivered. It works fine.
Here's an eBay search that should return some examples....
http://search.ebay.co.uk/search/sear...trypage=search
If you can find a video on how to fold them back up it is really very simple, once you know how.
Video -
"Tim"
tdodd is offline   Reply With Quote
light, recommend, tent
