| Re: finding number of shots taken-300d
can't check via the 300D like you can on 1D series, you will only know from the memory card if it has been the only one used from time of purchase, ie: take a photo, check the photo number on the lcd screen and if it's the original card then that will be the shutter count, this changes if using a couple of different cards, not sure if that makes sense?
Mike.
__________________ Canon 50D - Canon 100mm F2.8 Macro - Canon 400mm F5.6L - Tamrac Expedition 8x - Manfrotto 055CLB Tripod - Manfrotto 393 Head - Manfrotto 681B Monopod - Ergorest Multipod |
