Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 25th at 4:30am and include delivery.
Cokin Filter System atr1981 Digital Photography General Chat 23 28-09-2007 9:54 AM
Filters - to buy seperates or a filter system? ghibbett Digital Photography General Chat 7 11-09-2007 4:47 PM
Using a ND Filter playthefilm Digital Photography General Chat 4 24-07-2007 8:02 AM
Old 30-05-2008, 3:04 PM   #1 (permalink)
jonnypb's Avatar
Thanks: Gave 283, Got 558
ND and Filter system Help
Hoping to add a sigma 10-20 to my collection in the very near future and have been impressed and inspired by a lot of the long exposure landscape/seascape pictures (especially allymac's ) It's something I'm very interested in doing but not too sure about which filter system to go for.
I think I need an ND8 plus a CPL - Also see some people have a ND100, is this just a stonger filter than the ND8 to lose more stops of light?
Do I go for a screw in type as I'd imagine I'd just use them on the 10-20 which is 77mm or should I go for a filter set with a holder which can be used on different size lenses incase I want to use them on my Tamron 17-50 67mm?
If I go for a screw in 77mm filters do I need to go for the slim profile to help to eliminate any vignating on an UWA
Sorry for all the questions, just want to make sure I get the right stuff!
jonnypb is offline   Reply With Quote
allymac123 (30-05-2008)
Old 30-05-2008, 3:14 PM   #2 (permalink)
Conspicuous Member
stevegreen's Avatar
Thanks: Gave 1,143, Got 1,013
Re: ND and Filter system Help
Yep, it's a darker filter which adds 10 stops to the exposure.
The Cokin system has various ring sizes which screw in and then the filter holder slides onto that, its a decent enough system but can be a bit fiddly. It does of course allow you to use your filers on any size lens that has a screw mount though.
The 10-20mm Sigma will show signs of vignetting even with the Cokin slim holder from around 12mm to the widest, it's not that big a deal as it can easily be cloned out in PS. As for the screw in variety you would need to go for the slimline type just to make sure you get as little vignette as possible.
EOS 5D Classic~EF 24-70mm f/2.8L~EF 70-200mm f/2.8L IS~EF 50mm f/1.4~580EXII
Flickr Website Blog
stevegreen is offline   Reply With Quote
jonnypb (30-05-2008)
Old 30-05-2008, 3:37 PM   #3 (permalink)
tontoshorse's Avatar
Thanks: Gave 637, Got 532
The cokin system is also handy for graduated ND's (to prevent blown skies). Being in a holder means they can be rotated as well as moved vertically.
(still a bit of a faf though).
Don't think cokin do a higher than an 8.
My Flickr
tontoshorse is offline   Reply With Quote
Old 30-05-2008, 3:47 PM   #4 (permalink)
jonnypb's Avatar
that's one of the reasons I was leaning towards the screw in filters but still open to ideas
Old 30-05-2008, 3:50 PM   #5 (permalink)
The CPL on the cokin isn't user friendly either.
My Flickr
Old 30-05-2008, 3:58 PM   #6 (permalink)
jonnypb's Avatar
If you've got an ND filter on as well as a CPL how do you see the effect of the CPL?
Obviously if you just have a CPL on and you rotate it you can see the different effect it will create but if you've got an ND filter on blocking the light can you still see the effect of the CPL if you rotate it
Old 30-05-2008, 4:04 PM   #7 (permalink)
You soon learn to put the CPL in first, adjust it and then slot in the ND.
My Flickr
Old 30-05-2008, 4:11 PM   #8 (permalink)
Conspicuous Member
stevegreen's Avatar
How so? I have never had any issues with mine.
Flickr Website Blog
Old 30-05-2008, 4:16 PM   #9 (permalink)
I find it quite tight to rotate, there's not much of an edge to grip and I generally manage to get finger prints on it attempting to slide it into that 1st gap.
My Flickr
Old 30-05-2008, 4:24 PM   #10 (permalink)
Conspicuous Member
stevegreen's Avatar
I have always rotated the entire filter holder around the adaptor
Flickr Website Blog
Old 30-05-2008, 4:32 PM   #11 (permalink)
A very neat trick Mr Green, but no can do with a grad in it as well.
and I still get finger prints on it!
Also forgot to mention to the OP, that you can't fit the lens cover once you've got the holder fitted.
My Flickr
Old 30-05-2008, 4:39 PM   #12 (permalink)
Conspicuous Member
stevegreen's Avatar
Ahhhhhh I very VERY rarely use a grad and the cpl together, that's why I have not experienced it. I actually used my ND grad yesterday, first time in ages!
Flickr Website Blog
Old 30-05-2008, 9:43 PM   #13 (permalink)
jonnypb's Avatar
thanks to martin lewis i got a letter today from the abbey saying they are offering me £442 as a settlement for my PPI Insurance on a car loan i took out years ago - if anyone has taken a loan out in the past read the article you could claim some money!
looks like i'm off to buy a 10-20 and some filters
now to decide on the filters....... i'm leaning towards the screw filters and have seen several hoya ND8 filters and hoya CPL filters on ebay. The CPL Pro1 filters range from £40 to £130 for the same one (HK sellers) are the cheaper ones likely to be fake such as this one?
Has anyone got any recommended places to buy filters from?
thanks
Old 31-05-2008, 6:18 AM   #14 (permalink)
Thanks: Gave 0, Got 7
For Ebay i cannot recommend Albert from Kea Photo highly enough.
padi89 is offline   Reply With Quote
jonnypb (31-05-2008)
Old 31-05-2008, 9:41 AM   #15 (permalink)
allymac123's Avatar
Thanks: Gave 472, Got 430
Yeah that Hoya CPL you meantioned is the same as mine and is the same (roughly) as what I paid for mine. The good thing with that one is that it is slightly slim (so doesn't vignette at 10mm) but still has a filter thread too so when using a heavy ND you can put the ND on top. (with an ND8 you should be able to see through the lens fine unless its getting dark and your needing to do +30s exposures.) However as you have a 40D then you can just use the liveview
.......My flickr....... Canon - 40D | 400D | 10-22 | 17-55 F2.8 IS | 50 1.4 | 70-200 F2.8L IS | 100 Macro | 430EX | Manfrotto 055MF3 + 804RC2 | Velbon ULTRA LUX i F | Tamrac Expedition 8 | Crumpler Messenger Boy 7500
allymac123 is offline   Reply With Quote
filter, system
