Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 24th at 10:30am and include delivery.
Sony A700 icemanonline Digital Photography General Chat 4 19-03-2008 11:02 PM
SONY ALPHA A700 (BODY) - £635.00 after cashback Pirate!! Digital Photography General Chat 1 15-03-2008 1:35 PM
Sony Alpha A700 (Body) - Sub £800.00 Pirate!! Digital Photography General Chat 9 19-12-2007 8:32 PM
New Sony A700 DSLR loz Digital Photography General Chat 32 29-10-2007 10:27 PM
Sony Alpha A700 $1499 Thoughts Please madgames Digital Photography General Chat 5 08-10-2007 9:51 PM
Old 18-05-2008, 3:40 PM   #1 (permalink)
Pirate!!'s Avatar
Thanks: Gave 373, Got 732
Exclamation WARNING: Sony Alpha A700 & Sigma 70-300 APO DG
HEADS UP:
Sony A700 will strip AF gears in Sigma 70-300mm APO DG Macro.
I had heard of this phenomenon, but was advised the latest firmware 'cured' it.
NOT TRUE. I have no idea if same applies to A200/300/350.
Be aware.
Will post images in a few days. The A700 is AWESOME though.
Pirate!
First, I'll rob you blind, then negotiate a discount! flickr Jetphotos My Gear
Pirate!! is offline   Reply With Quote
Old 18-05-2008, 3:47 PM   #2 (permalink)
denno75uk's Avatar
Thanks: Gave 248, Got 531
Re: WARNING: Sony Alpha A700 & Sigma 70-300 APO DG
Will you be able to claim from Sony for that? Do they warn of it in the literature?
James. Ignore my member status. I'm not old and know very little. I'm just very opinionated and lonely.
Canon 30D, Tamron 17-50 2.8, Canon 28-105 3.5-4.5 USM II, Sigma EX 70-200 2.8 APO DG Macro flickr
denno75uk is offline   Reply With Quote
Old 18-05-2008, 4:21 PM   #3 (permalink)
Thanks: Gave 425, Got 2,079
Originally Posted by Pirate!! View Post
HEADS UP:
NOT TRUE.
What is not true? the problem or the "cure"?
Absolutely...
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 18-05-2008, 4:48 PM   #4 (permalink)
Pirate!!'s Avatar
Absolutely...
A700 firmware update V3 doesn't 'cure or prevent' Sigma AF gear stripping in 70-300mm APO DG Macro lens. Haven't read 'literature' but heard via other forums. Anyway, lens has to go to Sigma for repair now. Maybe Sigma will talk to Sony and ask *** is going on.
Have too many images to sift through now. Some top totty @ Thruxton. Racing wasn't bad either. Some nice candids of a few of the drivers. Give me a few days to sort out 100 odd images all shot in RAW.
Pirate!
Old 18-05-2008, 4:49 PM   #5 (permalink)
Pirate!!'s Avatar
I dunno? Maybe Sigma will give me some indication. Fortunately, my lens is still in warranty.
Pirate!
Old 18-05-2008, 6:17 PM   #6 (permalink)
Thanks: Gave 179, Got 202
I did warn you about this Pirate, sorry your lens got buggered, hope you get it sorted under warranty.
www.flickr.com/photos/simonr_uk It's a work in progress!
My kit: Nikon D90, Nikon 18-105 VR, Nikon 35mm F1.8 AF-S, Nikon 70-300 VR, Tokina 12-24 F4 II
Strobe is offline   Reply With Quote
Pirate!! (18-05-2008)
Old 18-05-2008, 7:10 PM   #7 (permalink)
Thanks: Gave 211, Got 328
That is bad luck! Sorry to hear about that.
There is a camera setting for "Slow AF" that is supposed to help. The issue is related to poor (plastic) mechanics within the lens.
flickr
springtide is offline   Reply With Quote
Old 18-05-2008, 7:18 PM   #8 (permalink)
Pirate!!'s Avatar
I found that out after the fact. Maybe Sigma (UK) will have a permafix for this issue. Am awaiting an email for return details. My Siggy 24-70mm seems unaffected. I got some right 'stotters' today too . . . am well peeved right now.
Pirate!
Old 18-05-2008, 10:58 PM   #9 (permalink)
Thanks: Gave 62, Got 25
Forgive my stupidity, but what does strip AF gears mean?
Knacker the AF motor??
andy_fozzy is offline   Reply With Quote
Old 19-05-2008, 7:06 AM   #10 (permalink)
Pirate!!'s Avatar
Andy,
Basically what I believe is happening is the A700 sends an electronic signal to the lens in order for the AF motor to activate. It would seem the Sigma 70-300mm cannot deal with with the high torque signal from the A700 thus the gearing inside the lens (the teeth/cogs) basically wear themselves out so they do not engage one-another any more, or if they do . . just barely so you get the lens juddering away like crazy where the gearing teeth are trying to engage each-other.
So yes . . . knacker the AF motor in the lens.
Either way, it only took 2 hours after first use for my lens to become a victim of the phenomenon. I thought it worth posting a separate thread due to the nature of the problem.
Also, ADOBE are a bunch of ******. Why use a different RAW formula that requires the user to buy even more expensive software to open RAW files? Jeez, is buying a new camera wasn't expensive enough.
Pirate!
andy_fozzy (19-05-2008)
Old 19-05-2008, 7:22 AM   #11 (permalink)
Crumbs that sounds bad.
I hope you get yours sorted mate
Thanks for explaining.
I wonder if the other Sony models are the same?
Pirate!! (19-05-2008)
Old 19-05-2008, 9:14 AM   #12 (permalink)
Andy,
The A700 has a new high torque motor in the body for improved AF speed on all (excluding HSM) lenses.
The motor in the body uses a "screw drive" to the lens to focus the lens. It's the internal gearing on the lens that has been "striped".
The issue appears to be that the cheaper Sigma lenses seem to have used components that are not up to the torque generated by the A700, so the A700 AF motor strips the plastic gearing within the lens. Changing the AF speed to "Low" reduces the torque generated by the body.
This only seems to be an issue on the cheaper Sigma lenses, since I guess this is where Sigma have used lower quality components. I have also read that the issue also existed with the Film Dynax 9, which also had a fast AF.
I know it doesn't really help, but I would be interested to see Sigma's response. They basically need to upgrate these components to fix the issue once and for all. Repairing with the same components isn't really a fix.
flickr
Old 19-05-2008, 9:21 AM   #13 (permalink)
Pirate!!'s Avatar
I'll keep you posted. Sigma UK basically said 'send it' and provide a detailed explanation of the problem/fault and also send a copy of the purchase invoice.
Hopefully in two weeks . . . .
Sigma ought to have a chat with Sony. Too higher torque or naff components? Either way it really shouldn't be an issue. No point setting the camera to 'low' if you need high speed AF for action (as I did yesterday). Anyway, now you all know.
Pirate!
Old 19-05-2008, 9:53 AM   #14 (permalink)
Thanks: Gave 12, Got 77
I take it this is an extra "feature" of Sony dSLRs?
inkinoo is offline   Reply With Quote
Old 19-05-2008, 9:58 AM   #15 (permalink)
Pirate!!'s Avatar
Not at all. Seems the A700 is to beefy for some Sigma lenses. Sigma ought to put out a product recall and have the affected models upgraded.
Pirate!
a700, alpha, apo, sigma, sony, warning
